[OpenFOAM.com] v1612+ Cannot run on Windows 7
Old   June 14, 2017, 20:33
Default v1612+ Cannot run on Windows 7
Rolanzo
Rolanzo is on a distinguished road
So I have installed OpenFOAM 1612+ on Windows 7 using following link.
http://www.openfoam.com/download/ins...ry-windows.php
This is my first time trying to run OpenFOAM on Windows, so according to instruction, I just went straight to OF_Env_Create after installation. Then I got the error as shown in pic1. I tried to run OpenFOAM_Start afterwards but obviously, it did not work, the terminal showed up for short time with some red sentences then disappeared as shown in pic2 (I tried running as a user and admin for both OF_Env_Create and OpenFOAM_Start).
I checked VisualMachine installed on Desktop, it turns out that the default system (Ubuntu 32-bit) is not running, so I tried to start manually but got error code as below, please also see log file as attached for more details.
Result Code:
E_FAIL (0x80004005)
Component:
ConsoleWrap
Interface:
IConsole {872da645-4a9b-1727-bee2-5585105b9eed}
Please kindly advise if I have done anything wrong or if I miss anything.
Thank you.
Rolanzo is offline   Reply With Quote
Old   June 15, 2017, 00:24
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
As far as I understand the error messages, the problems arises form the security system of your computer. The files to be executed are not digital signed.
Try to install with admin rights.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   June 15, 2017, 00:29
Rolanzo
Thank you so much for your response. So you mean that I should uninstall then reinstall while logging in as admin?
Old   June 15, 2017, 04:03
piu58's Avatar
Uwe Pilz
Exactly! You may get a box which asks for permission.
Uwe Pilz
Old   June 15, 2017, 12:53
Rolanzo
Ok! If I manage to successfully install, when I run do I have to login to admin account?
Old   June 15, 2017, 14:25
piu58's Avatar
Uwe Pilz
If you install it for "all users", not.
Uwe Pilz
Old   June 15, 2017, 18:43
Rolanzo
I tried to uninstall then reinstall as admin but still get the same error. Do you have any idea what might have caused this?
Thank you.
Old   June 21, 2017, 03:53
pgh
Pawan Ghildiyal
pgh is on a distinguished road
Hi Rolanzo
1) Problem :
I saw the log file that you attached and it show following message .
" VMSetError: VT-x is disabled in the BIOS for all CPU modes"
You need to switch on hardware virtualization from BIOS . This is one of prerequisites as mentioned in README file
http://openfoam.com/download/txt/ope...dme_v1612+.txt
Pre-requisites: --------------- 1) Hardware assisted virtualization should be enabled. If not already done, please enabled it from the BIOS mode (see below),then reboot your system twice before proceeding with this Installation. In Windows7, check if hardware-assisted Virtualization is switched on by running the Windows utility https://www.microsoft.com/en-us/down...d=592#filelist In Windows8 and 10 it can be checked via the Task Manager.
2) Solution:
You need to switch on hardware virtualization from BIOS and need to reboot you system twice at least . Then uninstall all component of OpenFOAM installation as mentioned in README file and install in again .
Thanks
Pawan
pgh is offline   Reply With Quote
[Other] How to install OpenFOAM under Windows? lzgwhy OpenFOAM Installation 19 October 7, 2023 04:27
Compile Fluent UDF with Windows 10 daniel_pramudita FLUENT 15 May 13, 2020 22:29
How to run OpenFoam commands with windows command line maksjood OpenFOAM Running, Solving & CFD 1 June 4, 2018 11:19
Run ansys 12.0 using batch mode (windows xp) mayan ANSYS 2 May 25, 2016 08:02
ctrl+c close all windows after the end of run immortality Lounge 20 July 7, 2013 08:16
