OpenFOAM 4.1 on OpenSUSE Leap 42.2
Hello foamers,
I think the instructions on the openfoamwiki page (http://openfoamwiki.net/index.php/In...M-4.1/openSUSE) are not complete. 1) Between steps 9 and 10 you should replace Code:
Field<scalar> processorWeights; Code:
Field<floatScalar> processorWeights; 2) After the installation, make the environment available by typing Code:
of41 Code:
mpicc: command not found @bgschaid & @wyldckat: Is it okay to add step 1 to the wiki? @all Does anyone know a solution for the problem described in 2)? Best regards, Kate |
Greetings Kate,
The second error should be fixable if you run the following command first: Code:
source /etc/profile.d/mpi-selector.sh If it doesn't work, the perhaps Open-MPI is not the default MPI toolbox in your openSUSE installation? As for the first error, I completely forgot about rechecking it when another bug report was issued: https://bugs.openfoam.org/view.php?id=2330 I did think that the bug report you indicated had already patched this issue in OpenFOAM 4, but it was sooner after reverted, hence the situation you've described. Let me build OpenFOAM 4.1 on openSUSE 42.1 following the steps on the wiki and then I'll add the bug fix to step #6. I do suspect that I only copy-paste-adapted the instructions and didn't test the instructions myself :( I'll update this post after I've finished testing. Best regards, Bruno |
Hello Bruno,
you were right. Problem 1 was didn't reappear after restarting. Thanks for your help. |
