[OpenFOAM.org] Compile ParaView-5.4-0 (from OpenFOAM-6) using Ubuntu 20.04
Like Tree1Likes
  • 1 Post By GerhardHolzinger
Old   March 22, 2021, 12:29
Default Compile ParaView-5.4-0 (from OpenFOAM-6) using Ubuntu 20.04
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
This is more a note to the universe than a question.
I have recently got a new machine with Ubuntu 20.04 on it, and I installed a couple of OpenFOAM versions on it.
For some stuff I needed an OpenFOAM-6 installation, hence I compiled one from source code.
With OpenFOAM itself, I encountered no problems, however, ParaView had some issues.
It turned out, that I needed to apply the changes described in this post, which are some changes to support Qt-5.11. On my machine (pretty vanilla Ubuntu 20.04 there is Qt 5.12.8).
Furthermore, I needed to install the qtxmlpatterns5-dev-tools package, since compiling ParaView stopped with an error.
Another change that was necessary, was this one.
souza.emer likes this.
Last edited by GerhardHolzinger; March 23, 2021 at 05:07. Reason: added final note
GerhardHolzinger is offline   Reply With Quote
Old   March 23, 2021, 02:49
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
I have recently got a new machine with Ubuntu 20.04 on it, ...
Hi Gerhard,
I'm curious about why you need to compile paraview from source at all. I've generally found that a precompiled paraview binary v5.6.3 or newer works quite well. The only thing might be if you need the catalyst insitu as well, in which case you can't avoid it.
LG
/mark
olesen is offline   Reply With Quote
Old   March 23, 2021, 05:10
Gerhard Holzinger
I think habit is the correct answer. I have always installed OpenFOAM from source, hence this is what I do by default.
Old   March 31, 2021, 13:37
Marco Pancaldi
Panca is on a distinguished road
Hi Gerhard,
I'm trying to install OpenFOAM 6 on ubuntu 20.04, but It's the first time I compile OpenFOAM from suorce code, and I'm not very expert.
Is possible to compile OpenFOAM without compile Paraview?
Panca is offline   Reply With Quote
Old   March 31, 2021, 13:45
Mark Olesen
Originally Posted by Panca View Post
Hi Gerhard,
This would be my standard answer regarding paraview :
https://develop.openfoam.com/Develop...raview-plugins
Of course, if you have Ubuntu 20.04, I would probably go for a precompiled binary:
https://develop.openfoam.com/Develop...ompiled/debian
Old   April 1, 2021, 06:30
Marco Pancaldi
Thank you, very usefull
This use the repository from openfoam.com, I need the version of the openfoam foundation, do you know if is possible install the binary of openfoam 6 in ubuntu focal?
Old   April 1, 2021, 10:38
Marco Pancaldi
I'ved found the binary, and resolved my problem.
Mark thankyou for your help
Old   November 14, 2021, 08:57
Andrea Di Ronco
Diro7 is on a distinguished road
Hi Gerhard,
LG
/mark
I'm trying to make PV work with OF6 on Ubuntu 20.04 LTS. After some troubles as described in this thread, I decided to go as you (sort of) suggest with the PV package available from the package manager (5.7.0), but what I've found is that PV fails to launch if I source the OF6 environment.
The error it gives is related to OpenMPI:
It looks like opal_init failed for some reason; your parallel process is
likely to abort.  There are many reasons that a parallel process can
fail during opal_init; some of which are due to configuration or
environment problems.  This failure appears to be an internal failure;
here's some additional information (which may only be relevant to an
Open MPI developer):
  opal_shmem_base_select failed
  --> Returned value -1 instead of OPAL_SUCCESS
It looks like orte_init failed for some reason; your parallel process is
fail during orte_init; some of which are due to configuration or
  opal_init failed
  --> Returned value Error (-1) instead of ORTE_SUCCESS
It looks like MPI_INIT failed for some reason; your parallel process is
fail during MPI_INIT; some of which are due to configuration or environment
problems.  This failure appears to be an internal failure; here's some
additional information (which may only be relevant to an Open MPI
developer):
  ompi_mpi_init: ompi_rte_init failed
  --> Returned "Error" (-1) instead of "Success" (0)
*** An error occurred in MPI_Init
*** on a NULL communicator
*** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
***    and potentially your MPI job)
I believe it probably depends on the fact that I compiled OF6 against the usual ThirdParty OpenMPI 2.1.1 (not being able to compile against the system OpenMPI 4.0.3).
So, just to provide a broader view, it seems that integrating a pre-compiled PV in a OF6 environment is not that straightforward. Of course I can launch PV in a separate terminal, but it's far from ideal so I think I'll try to give the shipped PV another try.
Andrea
Diro7 is offline   Reply With Quote
[OpenFOAM.org] Paraview command error. OpenFOAM 8, Ubuntu 20.04 sungmin130 OpenFOAM Installation 1 April 28, 2021 10:21
[OpenFOAM.com] Paraview command error. OpenFOAM 8, Ubuntu 20.04 sungmin130 OpenFOAM Installation 0 October 20, 2020 12:26
[OpenFOAM.com] Compile error OpenFoam v1912 on ubuntu 18.04 LTS dkeogh OpenFOAM Installation 4 June 11, 2020 09:11
[OpenFOAM.org] Can't seem to compile ParaView 4.1.0 (OpenFOAM 2.4.x, CentOS 7) me3840 OpenFOAM Installation 2 October 13, 2015 00:05
paraview not working after installing OpenFOAM in Ubuntu 12.04 Jackie Chen OpenFOAM Installation 5 October 9, 2014 06:28
