July 29, 2017, 02:52 |
Sig turboPerformance for OF4.1
Sohail
Rep Power: 12 |
Hello Everyone!!
I am hoping someone can help me with a problem I am facing. I am trying to install the turboPerformance utility for OF4.1 using instructions from here https://github.com/wyldckat/OSIG-Tur...ce-foam-extend I understand it is meant for FE3.2. How can I adapt it to work with OF4.1? Hope someone can help me with this! Thanks Sohail |
September 3, 2017, 15:09 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I haven't had the time needed to look better into this.
However, there is a main wiki page for the 'turboPerformance' library here: https://openfoamwiki.net/index.php/S...rboPerformance There you should have found this entry: Quote:
Use the branch for OpenFOAM 2.3.x as a basis. As for the changes needed to be done, try building the library by following the instructions on that repository. Then whenever you see a build error, try checking if it's related to any of these changes: http://www.openfoam.com/documentatio...rade-guide.php
turboperformance, utility |
[Other] Sig turboPerformance Library: Looking for updates beyond 1.6-ext and 1.5-dev | scnsc | OpenFOAM Community Contributions | 10 | September 26, 2021 21:25 |
Reviving the Turbulence SIG | tiam | OpenFOAM | 0 | May 7, 2018 11:14 |
Bug in turboPerformance for OF-2.3.x? | lentschi | OpenFOAM | 2 | August 24, 2014 04:53 |
OpenFOAM 2.2 + turboPerformance | lentschi | OpenFOAM | 0 | July 3, 2013 08:12 |
SIG Turbo ERCOFTAC Centrifugal Pump - OF Revision Problem? | marcelgt87 | OpenFOAM | 18 | June 26, 2012 08:59 |
