[OpenFOAM.org] paraView running Problem [not found]
Like Tree2Likes
  • 1 Post By wyldckat
Old   September 1, 2017, 02:07
Default paraView running Problem [not found]
Thomas
X.Thomas is on a distinguished road
Hi, I am new in using OpenFOAM, and I am preparing to learn from a simple demo. When I try to scan the mesh with the command paraFoam, there goes an error
FATAL ERROR : ParaView reader module libraries do not exist
         Please build the reader module before continuing
cd $FOAM_UTILITIES/postProcessing/graphics/PVReaders
./Allwclean
./Allwmake
but when I finish the 1st and 2nd commands and type the 3rd one and press ENTER ,there comes one more error
ERROR: ParaView not found in /home/xthomas/OpenFOAM/ThirdParty-5.x/platforms/linux64Gcc/ParaView-5.4.0
I am quite wonder the reason I got such a condition and could you please just give me some hints or solutions. Thank you.
X.Thomas is offline   Reply With Quote
Old   September 2, 2017, 06:48
Retired Super Moderator
Bruno Santos
Quick questions:
  1. Which installation instructions did you follow?
  2. Was ParaView 5.4.0 built with success or did you install the one from Deb packages?
Bashar likes this.
Old   September 13, 2017, 00:47
Bashar
Bashar is on a distinguished road
Originally Posted by wyldckat View Post
Quick questions:
I have a similar issue but with version3.0.1 . I followed the instruction on the link :
https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL
every thing is good and openfoam installation is working.However, when I tried to install paraview I got the following error:
ERROR: ParaView not found in /home/bashar/OpenFOAM/ThirdParty-3.0.1/platforms/linux64Gcc/ParaView-4.4.0
I followed step 13 on the above link but I got this error.
I hope you have time to read this.
Bashar
Bashar is offline   Reply With Quote
Old   September 13, 2017, 01:16
Bashar
Sorry I forgot to attach the log file :
[  GNU nano 2.3.1                                                         File: log.makePV
    qt        4.8.5
    version   4.4.0
    major     4.4
    build     Release
MISMATCH!
    specified 4.4.0
    found
removing old build directory
    /home/bashar/OpenFOAM/ThirdParty-3.0.1/build/linux64Gcc/ParaView-4.4.0
Configuring paraview-4.4.0 (major version: 4.4)
    MPI    support : true
    Python support : true
    MESA   support : false
    Qt dev support : true
    Source         : /home/bashar/OpenFOAM/ThirdParty-3.0.1/ParaView-4.4.0
    Build          : /home/bashar/OpenFOAM/ThirdParty-3.0.1/build/linux64Gcc/ParaView-4.4.0
    Target         : /home/bashar/OpenFOAM/ThirdParty-3.0.1/platforms/linux64Gcc/ParaView-4.4.0
    Build type     : Release
cmake -DCMAKE_INSTALL_PREFIX:PATH=/home/bashar/OpenFOAM/ThirdParty-3.0.1/platforms/linux64Gcc/ParaView-4.4.0 -DBUILD_SHARED_LIBS:BOOL=ON VTK_USE_RPATH:BOOL=OFF -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON -DBUI$
etc/tools/ParaView4Functions: line 420: cmake: command not found
    Starting make
make: *** No targets specified and no makefile found.  Stop.
real    0m0.003s
user    0m0.001s
sys     0m0.002s
    Done make
    Installing ParaView to /home/bashar/OpenFOAM/ThirdParty-3.0.1/platforms/linux64Gcc/ParaView-4.4.0
make: *** No rule to make target `install'.  Stop.
    Installation complete for paraview-4.4.0
    Set environment variables:
        export ParaView_DIR=/home/bashar/OpenFOAM/ThirdParty-3.0.1/platforms/linux64Gcc/ParaView-4.4.0
        export PATH=$ParaView_DIR/bin:$PATH
        export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-4.4
Done
^G Get Help                        ^O WriteOut                        ^R Read File                       ^Y Prev Page                       ^K Cut Text                        ^C Cur Pos
^X Exit                            ^J Justify                         ^W Where Is                        ^V Next Page                       ^U UnCut Text                      ^T To Spell
Thank you
Last edited by wyldckat; December 31, 2017 at 12:37. Reason: Repaired [CODE][/CODE] markers
Old   December 31, 2017, 12:42
Bruno Santos
Quick answer @Bashar: Sorry, I wasn't able to look into this anytime sooner. The problem seems to be that CMake was not built with success or is not installed... but since you didn't specify which Linux Distribution and version you were using, I'm not able to indicate what step you should have taken.
I hope you have solved this problem since then.
Bashar likes this.
Old   January 8, 2018, 17:08
Bashar
Thank you! Unfortunately, I was not able to solve this issue . I was trying to install it on my machine with Centos 7.
Old   January 14, 2018, 13:15
Bruno Santos
Quick answer: If you want to try again, please be certain that you follow the instructions written specifically for CentOS 7.1: https://openfoamwiki.net/index.php/I...HEL#CentOS_7.1
Furthermore, you can confirm if cmake is somehow installed by running the following commands:
which cmake
yum list installed cmake
rpm -q cmake
[General] Problem opening paraview (remote) alexvaleije ParaView 0 June 23, 2016 13:03
[General] Problem in using paraview meballav ParaView 11 October 12, 2012 17:03
Installation Problem with ParaView 3.12.0 on Scientific Linux 5.7 Wley OpenFOAM Installation 2 September 28, 2012 07:06
paraFoam running problem Aleksey_R OpenFOAM 2 November 27, 2009 19:18
problem with running parafoam & paraview padmanathan OpenFOAM 3 June 12, 2009 08:30
