[OpenFOAM.org] openFoam 2.3.x install on Ubuntu 16.04 in windows 10 |
October 19, 2017, 07:12 |
Andy Grey
I need to use 2.3.0 because it's the version which my university uses. *sigh* On doing Code:
sudo apt-get install openfoam230 Code:
openfoam230 : Depends: libopenmpi1.3 but it is not installable Recommends: libptscotch-dev but it is not going to be installed I figure I have to downgrade a lot of stuff but I'm having problems. Can anyone help? |
December 31, 2017, 12:11 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: I'm really late to your request... have you solved this or do you still need to install OpenFOAM 2.3.0 on Ubuntu 16.04?
If you still do, have you tried the instructions made available at the following page for Ubuntu 14.10: https://openfoamwiki.net/index.php/I...u#Ubuntu_14.10 ?
April 7, 2018, 17:05 |
Errors in Installing OF.2.3.0 in ubuntu 16.04
Bah.Mah
Rep Power: 9 |
Hello everyone.
I really need to install OF.2.3.0 in ubuntu 16.04, I followed the Installation/Linux/OpenFOAM-2.3.0/Ubuntu But I got so many errors while doing the making step, I have attached the make.log file. Please any help and I will be so grateful. Best regards |
April 8, 2018, 13:51 |
Bruno Santos
Rep Power: 128 |
Quick answer: I've started the instructions for OpenFOAM 2.3.0 on Ubuntu 16.04, although I haven't tested it yet. Please see this section: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04 - and continue following the instructions from step #11.
In other words, use the current state of your installation and try to continue it from there. Since you stopped midway, Don't forget to activate the OpenFOAM shell environment by running the following command on a new terminal window: Code:
of230
April 8, 2018, 17:39 |
Bah.Mah
Rep Power: 9 |
Many thanks, it worked .
April 8, 2018, 17:57 |
Bruno Santos
Rep Power: 128 |
Excellent, that fixes that!
In case you need to use foamyHexMesh, I've finished testing/fixing the instructions for it as well: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04
[OpenFOAM.org] I have trouble installing openfoam 5.0 on ubuntu 16.04 | haydii | OpenFOAM Installation | 5 | December 27, 2018 10:56 |
[OpenFOAM.org] OpenFOAM 3.0.1 from source in Ubuntu 16.04 | jandrey | OpenFOAM Installation | 4 | April 10, 2017 04:28 |
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs | Pier84 | OpenFOAM Installation | 4 | June 18, 2016 16:22 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
