Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[FSI] Attempting to compile the new FSI solver in foam-extend-3.1 (Ubuntu 14.04)
Old   May 26, 2015, 21:11
Default Attempting to compile the new FSI solver in foam-extend-3.1 (Ubuntu 14.04)
danny261083 is on a distinguished road
Hi Dr. Cardiff,
I was attempting to compile the new FSI solver in foam-extend-3.1 (Ubuntu 14.04) based on instructions given in http://openfoamwiki.net/index.php/Ex...re_interaction and http://www.tfd.chalmers.se/~hani/kur...OFLecFSI-1.pdf. However, I was getting the error '/usr/bin/ld: cannot find -lfluidStructureInteraction'. I would like to know whether there is an alternative method to compile the fsifoam solver.
Thanks & Regards
danny261083 is offline   Reply With Quote
Old   May 27, 2015, 11:32
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Originally Posted by danny261083 View Post
Hi Dr. Cardiff,
Thanks & Regards
Hi Danny,
The compilation instructions are as follows:
cd $WM_PROJECT_DIR/extend-bazaar
./Allwmake # to download the FluidStructureInteraction directory
cd FluidStructureInteraction/src
./Allwmake
If you get the compilation linking error "/usr/bin/ld: cannot find -lfluidStructureInteraction", this means that the fluidStructureInteraction library did not compile; so can you try compile it again and post the entire output of the wmake libso command here:
cd $WM_PROJECT_DIR/extend-bazaar/FluidStructureInteraction/src/fluidStructureInteraction
wmake libso
Philip
bigphil is offline   Reply With Quote
Old   September 1, 2015, 12:42
bryan
bcgooder is on a distinguished road
Originally Posted by bigphil View Post
Hi Danny,
./Allwmake
wmake libso
Philip
Dr. Cardiff,
I've been trying to compile the FluidStructureInteraction package following the instructions you've listed above. I was getting the "/usr/bin/ld: cannot find -lfluidStructureInteraction" message so I compiled
again using wmake libso but am still getting errors. I am posting the error output here and hopefully you could help figure out the problem.
Thanks,
Bryan
Make/linux64GccDPOpt/constitutiveModel.o
stressModels/constitutiveModel/constitutiveModel.C: In constructor ‘Foam::constitutiveModel::constitutiveModel(const volSymmTensorField&, const volVectorField&)’:
stressModels/constitutiveModel/constitutiveModel.C:116:13: error: no matching function for call to ‘Foam::IOReferencer<Foam::solidInterface>::IOReferencer(Foam::IOobject, Foam::solidInterface&)’
stressModels/constitutiveModel/constitutiveModel.C:116:13: note: candidates are:
In file included from /home/bryan/OpenFOAM/foam-extend-3.1/src/foam/lnInclude/IOReferencer.H:139:0,
                 from stressModels/constitutiveModel/constitutiveModel.H:53,
                 from stressModels/constitutiveModel/constitutiveModel.C:27:
/home/bryan/OpenFOAM/foam-extend-3.1/src/foam/lnInclude/IOReferencer.C:53:1: note: Foam::IOReferencer<Type>::IOReferencer(const Foam::IOobject&, Type*) [with Type = Foam::solidInterface]
/home/bryan/OpenFOAM/foam-extend-3.1/src/foam/lnInclude/IOReferencer.C:53:1: note:   no known conversion for argument 2 from ‘Foam::solidInterface’ to ‘Foam::solidInterface*’
/home/bryan/OpenFOAM/foam-extend-3.1/src/foam/lnInclude/IOReferencer.C:31:1: note: Foam::IOReferencer<Type>::IOReferencer(const Foam::IOobject&) [with Type = Foam::solidInterface]
/home/bryan/OpenFOAM/foam-extend-3.1/src/foam/lnInclude/IOReferencer.C:31:1: note:   candidate expects 1 argument, 2 provided
In file included from stressModels/constitutiveModel/constitutiveModel.H:53:0,
/home/bryan/OpenFOAM/foam-extend-3.1/src/foam/lnInclude/IOReferencer.H:85:7: note: Foam::IOReferencer<Foam::solidInterface>::IOReferencer(const Foam::IOReferencer<Foam::solidInterface>&)
 class IOReferencer
/home/bryan/OpenFOAM/foam-extend-3.1/src/foam/lnInclude/IOReferencer.H:85:7: note:   candidate expects 1 argument, 2 provided
make: *** [Make/linux64GccDPOpt/constitutiveModel.o] Error 1
Last edited by wyldckat; September 1, 2015 at 16:06. Reason: Added [CODE][/CODE] markers
bcgooder is offline   Reply With Quote
Old   November 30, 2018, 10:36
Tom
russel60 is on a distinguished road
Greetings All,
I hate to bring up topics that are 3 years old, but I am having the same exact problem as Danny261083 when I try to install the FluidSolidInteraction toolkit. It appears that the fluidSolidInteraction library did not compile. I tried to manually compile the library following Dr. Cardiff's instructions, but it did not work.
Hi Danny,
./Allwmake
wmake libso
Philip
I am running Foam-Extend 4.0 on Bash On Ubuntu On Windows. I tried following WyldKat's instructions on
http://openfoamwiki.net/index.php/Ex...oam-extend_3.2
but have had no success.
Does anyone have any tips to help the fluidSolidInteraction library to compile? Any help would be greatly appreciated!!
Thanks!
russel60 is offline   Reply With Quote
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 22:07
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
