[OpenFOAM.com] root in openfoam docker
Like Tree5Likes
  • 1 Post By rcastilla
  • 4 Post By MakisH
Old   February 13, 2016, 14:18
Default root in openfoam docker
jeremy rutman
jeremy rutman is on a distinguished road
I pulled the openfoam docker, which is built on centos which i'm not familiar with (I am an ubuntu user) . 'sudo' isn't recognized nor are my usual texteditors (nano, emacs) , nor can i install with yum without being root....so unless someone has some way out I guess I will just install on the metal and skip the docker which otherwise seems like a nice idea.
jeremy rutman is offline   Reply With Quote
Old   February 22, 2016, 09:45
Robert Castilla
rcastilla is on a distinguished road
It seems that you can access to root with the same password as the root acount in your local linux system.
It worked for me.
Regards
Robert
pgh likes this.
rcastilla is offline   Reply With Quote
Old   April 5, 2016, 07:50
shangyan
shangyan is on a distinguished road
Hi,jeremy rutman
start your system in virtual box.run "passwd".It will require a new password, set one.Start your Docker and openfoam.Type su and input the password you set.
shangyan is offline   Reply With Quote
Old   October 24, 2017, 07:31
MakisH is on a distinguished road
I tried OpenFOAM v1706 on Ubuntu 16.04, using the Docker-installation method, which is based on the installOpenFOAM and a startOpenFOAM scripts.
A workaround I found to login as root inside was to edit the startOpenFOAM script and modify:
docker exec -it of_v1706 /bin/bash -rcfile /opt/OpenFOAM/setImage_v1706.sh
to this (i.e. add the "-u 0"):
docker exec -u 0 -it of_v1706 /bin/bash -rcfile /opt/OpenFOAM/setImage_v1706.sh
I then ran the startOpenFOAM script as my normal user and I was logged in as root.
kiski, arvindpj, Swift and 1 others like this.
MakisH is offline   Reply With Quote
docker ubuntu centos
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
[OpenFOAM.com] Accessing the root account via Docker garumple OpenFOAM Installation 7 October 9, 2021 05:22
[OpenFOAM.com] v1712 with Docker on Ubuntu 17.10. Use same docker in Windows 10? amh@inventas.no OpenFOAM Installation 0 January 30, 2018 08:59
[OpenFOAM.org] How to get OpenFoam compiled on a cluster with CentOS 6.5 and no root permissions hulli OpenFOAM Installation 2 November 6, 2014 18:01
Environment errors with .deb install and ubuntu 13.04 64 bit jonathanbyrn OpenFOAM Installation 14 September 26, 2013 05:22
