[Other] Problems running Allwmake.sh in CFDSupport's v1710 |
October 3, 2017, 03:14 |
gemxx
Rep Power: 11 |
When I run Allwmake.sh file, there are the errors on the command line.
wmake lib.so . make: stat: /root/OpenFOAM/root-dev-17.10-cfdsupport/platforms/linux64Gcc62DPInt32Opt/lib/fftw-3.3.3/include/fftw3.h: Permission denied make: *** No rule to make target 'lib.so'. Stop. g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I/home/kale/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/randomProcesses/lnInclude -I/home/kale/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/sampling/lnInclude -I../../lib/lnInclude -IlnInclude -I. -I/home/kale/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/OpenFOAM/lnInclude -I/home/kale/OpenFOAM-in-Box-17.10/OpenFOAM-dev/src/OSspecific/POSIX/lnInclude -fPIC -c surfaceNoise.C -o Make/linux64Gcc62DPInt32Opt/surfaceNoise.o surfaceNoise.C:61:28: fatal error: FoamFftwDriver.H: No such file or directory #include "FoamFftwDriver.H" ^ compilation terminated. /home/kale/OpenFOAM-in-Box-17.10/OpenFOAM-dev/wmake/rules/General/transform:25: recipe for target 'Make/linux64Gcc62DPInt32Opt/surfaceNoise.o' failed make: *** [Make/linux64Gcc62DPInt32Opt/surfaceNoise.o] Error 1 I think that it is related to the permission of platforms directory, but I couldn't solve this problem. Could you please help me about the reason of this error? Last edited by gemxx; October 4, 2017 at 03:40. |
December 31, 2017, 11:52 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I'm a bit late on this, but from the look of it, it looks like the problem has to do with the command being executed as "root" instead of "kale", which results in not finding the correct installation paths.
Because it looks like the path "/root/OpenFOAM/root-dev-17.10-cfdsupport/" does not exist, while the ones at "/home/kale/OpenFOAM-in-Box-17.10/" do exist.
[OpenFOAM.com] problems running in parallel on Mac OS X and Windows: only 1 cpu | windscion | OpenFOAM Installation | 20 | June 5, 2020 16:27 |
Problems detected after running more than 500 iterations | JX- | FLUENT | 3 | February 21, 2017 11:31 |
Problems running icoFoam: sigSegv with 4x mesh resolution | SUBHANKAR | OpenFOAM Running, Solving & CFD | 4 | December 29, 2016 22:53 |
running CFX 11.0 on Fedora 7 : display problems | Eric Joubarne | CFX | 1 | October 3, 2007 16:51 |
Problems in a Background running of Intel Fortran | Minsuk Choi | Main CFD Forum | 2 | February 11, 2005 04:55 |
