Paraview 5.4 in shell environment of5x - Segmentation fault (core dumped)
1 Attachment(s)
Dear foamer,
I am quite new to OpenFoam and Ubuntu system (16.04LTS 64bit - Intel® Xeon(R) CPU E5345 @ 2.33GHz × 8 ). I try to install OpenFOAM 5.0 and Paraview 5.4.0 following the guide of http://openfoamwiki.net/index.php/Installation/Linux/OpenFOAM-5.x/Ubuntu#Ubuntu_16.04 . It was fine for OpenFoam, but paraview cannot work. Noted that when I enable shell environment with alias "of5x" (as guided by website). Code:
long@LD:~$ of5x I have tried to remove and reinstall but it still happened. However, when I run paraview without shell environment (new terminal). Of course, the system itself does not have paraview. I installed paraview 5.0 from Repository. It works new terminal Code:
sudo apt-get update Some information for diagnosing: I ran following code to attach paraviewLibrary and attached with this post Code:
ldd $(echo $ParaView_INCLUDE_DIR | sed -e 's=include=lib=')/libvtkpqCore-pv5.4.so > paraviewLibraries.log Then I check GPU: Code:
glxinfo | grep OpenGL Code:
lspci -v -s $(lspci | grep ' VGA ' | cut -d" " -f 1) Finally, I reinstall Nvidia drivers by sudo add-apt-repository ppa:graphics-drivers sudo apt-get update sudo apt-get install nvidia-current nvidia-settings But the results give another error glxinfo | grep OpenGL Xlib: extension "NV-GLX" missing on display ":0". Xlib: extension "NV-GLX" missing on display ":0". Xlib: extension "NV-GLX" missing on display ":0". Xlib: extension "NV-GLX" missing on display ":0". Xlib: extension "NV-GLX" missing on display ":0". Xlib: extension "NV-GLX" missing on display ":0". Xlib: extension "NV-GLX" missing on display ":0". Xlib: extension "NV-GLX" missing on display ":0". Xlib: extension "NV-GLX" missing on display ":0". Xlib: extension "NV-GLX" missing on display ":0". X Error of failed request: BadValue (integer parameter out of range for operation) Major opcode of failed request: 155 (GLX) Minor opcode of failed request: 24 (X_GLXCreateNewContext) Value in failed request: 0x0 Serial number of failed request: 35 Current serial number in output stream: 36 |
Hi foamer,
I figured out my problem at: https://askubuntu.com/questions/7955...quadro-nvs-285 My problem is my graphic card is not work with ubuntu 16.04. However, when I use Gnome flashback, it is fine. I am so happy |
