[OpenFOAM.org] Paraview 5.4 in shell environment of5x - Segmentation fault (core dumped)
Like Tree1Likes
  • 1 Post By dslbkxd
Old   February 1, 2018, 06:49
Default Paraview 5.4 in shell environment of5x - Segmentation fault (core dumped)
Doan Sy Long
dslbkxd is on a distinguished road
Dear foamer,
I am quite new to OpenFoam and Ubuntu system (16.04LTS 64bit - Intel® Xeon(R) CPU E5345 @ 2.33GHz × 8 ). I try to install OpenFOAM 5.0 and Paraview 5.4.0 following the guide of http://openfoamwiki.net/index.php/Installation/Linux/OpenFOAM-5.x/Ubuntu#Ubuntu_16.04 . It was fine for OpenFoam, but paraview cannot work. Noted that when I enable shell environment with alias "of5x" (as guided by website).
long@LD:~$ of5x
long@LD:~$ paraview
To avoid .foam file and .openFoam. I ran code paraview -buildtin but still error with Segmentation fault.
I have tried to remove and reinstall but it still happened. However, when I run paraview without shell environment (new terminal). Of course, the system itself does not have paraview. I installed paraview 5.0 from Repository. It works
new terminal
sudo apt-get update
sudo apt-get install paraview
Anyone can help me to overcome this problem with paraView 5.4.
Some information for diagnosing:
I ran following code to attach paraviewLibrary and attached with this post
ldd $(echo $ParaView_INCLUDE_DIR | sed -e 's=include=lib=')/libvtkpqCore-pv5.4.so > paraviewLibraries.log
gzip < paraviewLibraries.log > paraviewLibraries.log.gz
pwd
log.makePV aslo attached here
Then I check GPU:
glxinfo | grep OpenGL
OpenGL vendor string: nouveau
OpenGL renderer string: NV44
OpenGL version string: 2.1 Mesa 17.3.3
OpenGL shading language version string: 1.20
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 2.0 Mesa 17.3.3
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16
OpenGL ES profile extensions:
lspci  -v -s  $(lspci | grep ' VGA ' | cut -d" " -f 1)
07:00.0 VGA compatible controller: NVIDIA Corporation NV44 [Quadro NVS 285] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: NVIDIA Corporation NV44 [Quadro NVS 285]
	Flags: bus master, fast devsel, latency 0, IRQ 25
	Memory at dd000000 (32-bit, non-prefetchable) [size=16M]
	Memory at c0000000 (64-bit, prefetchable) [size=256M]
	Memory at de000000 (64-bit, non-prefetchable) [size=16M]
	Expansion ROM at 000c0000 [disabled] [size=128K]
	Capabilities: <access denied>
	Kernel driver in use: nouveau
	Kernel modules: nvidiafb, nouveau
By somehow, the system is not capable to access GPU (Capabilities: <access denied>). But it works for paraview5.0 without shell enviroment
Finally, I reinstall Nvidia drivers by
sudo add-apt-repository ppa:graphics-drivers
sudo apt-get update
sudo apt-get install nvidia-current nvidia-settings
But the results give another error
Xlib: extension "NV-GLX" missing on display ":0".
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 155 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 35
Current serial number in output stream: 36
dslbkxd is offline   Reply With Quote
Old   February 3, 2018, 00:56
Doan Sy Long
Hi foamer,
I figured out my problem at: https://askubuntu.com/questions/7955...quadro-nvs-285
My problem is my graphic card is not work with ubuntu 16.04. However, when I use Gnome flashback, it is fine. I am so happy
wyldckat likes this.
paraview 5.4.0
[OpenFOAM] PARAVIEW aborted (core dumped) dewey ParaView 1 October 13, 2016 03:21
How to get Python Shell into ParaView 3.8.1? blaise OpenFOAM Installation 3 July 24, 2012 04:58
ParaView Segmentation fault zzli OpenFOAM Bugs 3 November 14, 2008 06:07
ParaView Segmentation fault zzli OpenFOAM Bugs 0 November 14, 2008 00:51
ParaView Segmentation fault zzli OpenFOAM Bugs 0 November 14, 2008 00:48
