February 5, 2018, 06:07 |
SnappyHexMesh with MPICH
Panchatcharam Mariappan
Rep Power: 11 |
I compiled OpenFOAM using MPICH. All applications like interFoam, icoFoam, were compiled without any trouble. But, I did not find SnappyHexMesh under platforms directory. I recompiled snappyhexmesh using wmake, I understand that it is not at all compiling. Have anyone tried OpenFOAM-5.x with MPICH flag and compiled snappyhexmesh? |
February 5, 2018, 09:06 |
Rep Power: 11 |
I found the solution myself. It was an error with MPI flag of scotch and ptscotch. I have compiled MPICH at a different location, not at the thirdparty directory. So, it tried to compile with system openmpi for snappyhexmesh. Fixed by changing $FOAM_MPI in etc/conf.sh/mpi.
mpich, openfoam 5.x, snappyhexmesh |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 11:55 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
