[OpenFOAM.org] Questions about using the tutorials for OpenFOAM 5.0 on Ubuntu 16.04.3 |
February 11, 2018, 00:35 |
Patrick Isherwood
So I don't have much background with linux so please bear with me. I installed set up a dual boot of ubuntu 16.04.3 on my windows 10 laptop and have attempted to install OpenFOAM. I was able to install OpenFOAM but from what I gather I need to give my user access to the root directory since I have installed it in the opt directory. I couldn't edit or execute the files because they were in a root directory so I moved the tutorials to the home directory. I can now edit the files but wen i run OpenFOAM commands it gives me a 'command cannot be found' error when i try and run a simulation.
my question: 1. is there a easy safe way I can get access to the root directory as a standard user 2. is there an easy way to simply install openfoam in the home directory so I don't have to have root access to access the files 3. is there a piece of this that I am just not understanding (i honestly assume this has to be part of my problem) again im real new to this. Thanks!! |
February 12, 2018, 16:51 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: Which installation instructions did you follow?
February 12, 2018, 17:45 |
#3 | |
Patrick Isherwood
https://openfoam.org/download/5-0-ubuntu/ |
February 12, 2018, 17:51 |
Bruno Santos
Rep Power: 128 |
Quick answer: Then you don't need to worry about the files having been installed at "/opt". That installation will by default be available for any normal user.
If you run the following command: Code:
ls -ld /opt/openfoam5 Code:
drwxr-xr-x 10 root root 4096 Nov 5 23:11 /opt/openfoam5/ This means that as a normal user, you should be able to use OpenFOAM without problems. All you need to do is execute the following command as a normal user, in order to be able to run OpenFOAM's applications: Code:
source /opt/openfoam5/etc/bashrc |
May 27, 2018, 13:57 |
#5 | |
command not found, istallation help, opefoam, root access, ubuntu |
[OpenFOAM.org] I have trouble installing openfoam 5.0 on ubuntu 16.04 | haydii | OpenFOAM Installation | 5 | December 27, 2018 11:56 |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 6, 2018 00:48 |
[waves2Foam] Questions about wave2Foam tutorials | TXQ | OpenFOAM Community Contributions | 5 | January 10, 2018 02:41 |
[foam-extend.org] foam-extend 3.2 on Ubuntu 12.04, Floating point exception for tutorials | arsalan.dryi | OpenFOAM Installation | 7 | November 14, 2016 18:33 |
Simple questions regarding CCM+ tutorials | daniel1030 | STAR-CCM+ | 2 | December 28, 2014 01:03 |
