[Other] Using different MPI types and versions with OpenFOAM |
May 15, 2018, 08:08 |
Rep Power: 12 |
I have a few questions I've been unable to find the answers to, or the answers were for very old versions of OpenFOAM. I know you can use different types and versions of MPI with OpenFOAM by changing some settings before compilation. The types include the OpenMPI that comes in the ThirdParty folder, MPICH, and Intel MPI. There are many different versions of these MPIs. In the past, I've used OpenFOAM with the default OpenMPI that comes with the ThirdParty folder, and with a previously installed version of OpenMPI. Questions: 1. Why does OpenFOAM include an old version of OpenMPI? It's 1.5.X or something like that. The current OpenMPI version is 3.1.0. 2. Does OpenFOAM support newer versions of OpenMPI? 3. Are there any advantages/disadvantages to using a newer version of OpenMPI, e.g. 3.1.0? I know the major OpenMPI versions are not backwards compatible. I guess an advantage is that the newer OpenMPI's are probably better (faster?). 4. How difficult is it to use a different MPI, e.g. MPICH, with OpenFOAM? I saw in an old thread that in an older version of OpenFOAM you had to change about 6 settings and add a compilation file (or something like that) to get MPICH to work. Is there any documentation for how to do it with the latest OpenFOAMs? Part of the reason I'm asking is because I'm building my own cluster with Infiniband. I have to build everything from source (I can't use the precompiled OpenFOAM because it's a cluster), and I'm trying to decide between using the OpenMPI that comes in the ThirdParty folder or the latest version. Thanks! |
May 18, 2018, 11:50 |
Rep Power: 12 |
1. Still not sure about this.
2. OpenFOAM does support newer versions of OpenMPI. You can either compile it beforehand for the whole system and change the mpilib variable in the main openfoam bashrc to systemopenmpi, or put the untar'd folder in the ThirdParty folder and modify the config.sh script (in the OpenFOAM/etc folder) to point to that particular version, then the ThirdParty make file will make it with the ThirdParty Allwmake. 3. I couldn't find any disadvantages to using a newer version. In fact, I suggest it due to new features. 4. Intel and MPICH is similar to the answer to question 2, but I think there are a few more settings you have to modify. |
May 28, 2018, 03:31 |
#3 | |
Mark Olesen
Rep Power: 40 |
To get a different openmpi version, you would normally change two (or three) files. In etc/prefs.sh you define your WM_MPLIB=OPENMPI. The openmpi version can be changed either by editing the etc/config.sh/mpi file, or by creating a new etc/config.sh/openmpi file with the entry (FOAM_MPI=openmpi-3.1.0) ... Note that in both cases, these changes can also be made for a single user by creating the appropriate files in the ~/.OpenFOAM directory. See foamEtcFile -help, or foamEtcFile -list for more information about the directories searched. /mark |
mpi, openfoam |
OpenFOAM.com versus OpenFOAM.org: Which version to use? | wyldckat | OpenFOAM | 19 | March 25, 2023 07:50 |
Selectors in Foam Solvers and Data types associated | mathartist | OpenFOAM Programming & Development | 0 | June 12, 2018 04:38 |
Do different openfoam versions have different formats of the configuration files? | suryansh | OpenFOAM | 1 | May 30, 2016 11:47 |
Do different openfoam versions have different formats of the configuration files? | suryansh | OpenFOAM Running, Solving & CFD | 0 | May 30, 2016 10:14 |
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 1 | November 7, 2015 15:16 |
