[OpenFOAM.com] 1712 installation
Old   February 21, 2018, 15:19
Default 1712 installation
Brian
bbrown57 is on a distinguished road
Are there any instructions for installing OpenFOAM 1712? I tried using the 1612+ instructions, modifying them for the version I need, but they do not produce a working OpenFOAM installation.
Edit: I need to compile OpenFOAM as it is for use on a compute cluster with MPI.
bbrown57 is offline   Reply With Quote
Old   February 24, 2018, 18:20
Retired Super Moderator
Bruno Santos
Quick answer/question: Aren't the official instructions good enough? Namely these: https://www.openfoam.com/code/build-guide.php
If they aren't, which Linux Distribution are you using?
how do i fix installation error of ansys 19.0 on ubuntu 18.04 rid_taki ANSYS 15 June 7, 2021 06:32
[foam-extend.org] A smooth installation of foam-3.0-extend on OpenSUSE 13.1 64-bits cookcaptain OpenFOAM Installation 7 May 26, 2015 11:22
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 13:29
