February 21, 2018, 15:19 |
1712 installation
Brian
Rep Power: 8 |
Are there any instructions for installing OpenFOAM 1712? I tried using the 1612+ instructions, modifying them for the version I need, but they do not produce a working OpenFOAM installation.
Edit: I need to compile OpenFOAM as it is for use on a compute cluster with MPI. |
February 24, 2018, 18:20 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer/question: Aren't the official instructions good enough? Namely these: https://www.openfoam.com/code/build-guide.php
If they aren't, which Linux Distribution are you using?
how do i fix installation error of ansys 19.0 on ubuntu 18.04 | rid_taki | ANSYS | 15 | June 7, 2021 06:32 |
[foam-extend.org] A smooth installation of foam-3.0-extend on OpenSUSE 13.1 64-bits | cookcaptain | OpenFOAM Installation | 7 | May 26, 2015 11:22 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Installation problems | shellbell1999 | OpenFOAM Installation | 9 | April 6, 2006 13:29 |
