OpenFOAM-v1712 installation with intel and mpt - Kahip
Old   March 12, 2018, 10:43
Default OpenFOAM-v1712 installation with intel and mpt - Kahip
cecile
cecile is on a distinguished road
I am currently trying to install OpenFoam v1712 on a cluster with intel compiler 16 and mpt 2.12.
I managed recently to install OpenFoam 4.1 with intel compiler 16 and mpt 2.12 but with OpenFoam v1712 I have issues with Kahip building. There are lots of error like this one :
/sw/compil/gcc/5.2.0/include/c++/5.2.0/bits/stl_iterator_base_types.h(154): error: name followed by "::" must be a class or namespace name
typedef typename _Iterator::iterator_category iterator_category;
detected during:
instantiation of class "std::__iterator_traits<_Iterator, void> [with _Iterator=PathID={unsigned int}]" at line 163
instantiation of class "std::iterator_traits<_Iterator> [with _Iterator=PathID={unsigned int}]" at line 31 of "partition/coarsening/matching/gpa/path_set.cpp"
My Allwmake.log file is invalid (?) and I didn't manage to attach it.
I don't know why it is looking in gcc directory since i use intel compiler ....or i think I use Intel.
If anyone has a suggestion to help me .....
Thanks in advance ,
CÚcile
cecile is offline   Reply With Quote
Old   March 13, 2018, 05:41
cecile
Hello !
Ok, I managed to solve this issue : my libstdc++ librairie wasn't the good one !
Now I have another issue compiling openFoam sources.
It stops at the very beginning with this error :
db/dictionary/dictionarySearch.C(327): error: invalid type conversion: "Foam::dictionary::const_searcher" to "const Foam::dictionary::searcher &"
return static_cast<const searcher&>(finder);
The full log file is attached.
Does anyone has ever encountered such an error ? What is it due to ?
Thanks in advance
Have a nice day
Old   March 22, 2018, 09:55
Mark Olesen
olesen will become famous soon enough
Originally Posted by cecile View Post
Hello !
This is an interesting one. This should normally work, but obviously doesn't in your case. The intent is to search within the dictionary (normally read-only), but allow explicit casting to the other (read/write) version.
It's rather unfortunate if you've waited a long time and received no answer, but it's only by chance that I read the forum.
I've opened an issue
https://develop.openfoam.com/Develop...lus/issues/780
but I think I would need your assistance to ensure that we get a fix that actually works for you.
/mark
olesen is offline   Reply With Quote
Old   March 22, 2018, 09:56
Mark Olesen
Sorry double posted, but please do follow up on this on the gitlab side.
Thanks
/mark
Old   March 22, 2018, 09:58
Mark Olesen
For Gcc we've added -fpermissive when compiling kahip.
I think that your intel compiler might also be too old.
Old   March 23, 2018, 05:44
cecile
Thank you Mark for your answer !
Concerning kahip i am currently trying to install intel 2018 but i have license pb so it may take a while ...
For the second issue I will follow up on this on the gitlab side and let you know .
Thanks again
CÚcile
Thread Tools
Trackbacks are On
Compile OF2.1 with Intel Icc and Intel MPI hewei OpenFOAM Installation 7 February 12, 2013 16:18
