[OpenFOAM.org] E: Unable to locate package openfoam4 |
April 21, 2018, 14:15 |
Joćo Gil
Rep Power: 8 |
Hello everyone!
I am running a VirtualBox machine with Linux Mint 17.3 and followed the instructions to install OpenFOAM 4.1 in this link: https://openfoam.org/download/4-1-ubuntu/ When I input this instruction: sudo apt-get -y install openfoam4 An error appears saying "Unable to locate package openfoam4". Why is this happening? The packages exist. I followed the link in a browser and they are there. How could I solve this issue? By changing the distro of Linux? How to install the package by hand? I want to avoid installing by source because it takes loads of time. Thanks, Joćo Gil |
April 22, 2018, 14:31 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Linux Mint is based on Ubuntu, but uses other versions names. You will have to check which Ubuntu version your Linux Mint matches up to.
Example of how to set-it-up with Linux Mint 18.2: Problem for OF-dev on linuxMint 18.2 Sonya
April 22, 2018, 14:43 |
Joćo Gil
Rep Power: 8 |
Thanks for your reply!
These are the versions; https://en.wikipedia.org/wiki/Linux_...ersion_history Linux Mint17.3 is based on Ubuntu 14.04. I was also able to speak with CFD Support and they confirmed to me that the packages don't exist and the only way to install it is by source, which takes a lot of time and has some issues, namely installing Paraview (for some reason, it doesn't install it!) If someone is also familiar with these issues, how did you avoid them? Thanks, Joao Gil |
April 22, 2018, 14:47 |
Bruno Santos
Rep Power: 128 |
locate, openfoam4.1, package, unable |
Display Modes | |
[foam-extend.org] paraview not runing? (foam extended 3.2 and ubuntu 15.04) | Milan2013 | OpenFOAM Installation | 23 | April 20, 2017 06:49 |
[OpenFOAM.org] Building OpenFOAM 3.0.1 on Ubuntu 16.04 - failed | erico | OpenFOAM Installation | 30 | February 2, 2017 10:24 |
Prolem installing OpenFOAM Ver 2.3.0 source in Ubuntu 13.1.0 on VMware | zandi | OpenFOAM Installation | 5 | March 31, 2014 04:57 |
OF 1.6 ext on Ubuntu 12.10 (64 bit) compilation errors | dreamilam | OpenFOAM Installation | 7 | April 21, 2013 06:43 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
