June 19, 2018, 00:31 |
v1712 build error
Abe
Rep Power: 9 |
Hi guys,
I am trying to build openFoam on Fedora 28. I am getting some warnings, which end in an error 1 (I shortened it so that I could post): Code:
======================================== wmake libo (POSIX) Making dependency list for source file printStack.C Making dependency list for source file fileMonitor.C Making dependency list for source file memInfo.C Making dependency list for source file cpuInfo.C Making dependency list for source file clockTime.C Making dependency list for source file cpuTime.C Making dependency list for source file POSIX.C Making dependency list for source file fileStat.C Making dependency list for source file timer.C Making dependency list for source file regExp.C Making dependency list for source file sigWriteNow.C Making dependency list for source file sigStopAtWriteNow.C Making dependency list for source file sigQuit.C Making dependency list for source file sigInt.C Making dependency list for source file sigSegv.C Making dependency list for source file sigFpe.C g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c signals/sigFpe.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/signals/sigFpe.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c signals/sigSegv.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/signals/sigSegv.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c signals/sigInt.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/signals/sigInt.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c signals/sigQuit.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/signals/sigQuit.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c signals/sigStopAtWriteNow.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/signals/sigStopAtWriteNow.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c signals/sigWriteNow.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/signals/sigWriteNow.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c regExp.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/regExp.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c timer.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/timer.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c fileStat.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/fileStat.o In file included from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/token.H:46, from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/Istream.H:47, from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/ISstream.H:39, from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/IOstreams.H:38, from fileStat.C:27: /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/typeInfo.H: In instantiation of ‘To& Foam::dynamicCast(From&) [with To = Foam::token::Compound<Foam::List<int> >; From = Foam::token::compound]’: /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/FixedListIO.C:173:13: required from ‘Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::FixedList<T, Size>&) [with T = int; unsigned int Size = 13]’ /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/FixedListIO.C:152:15: required from ‘Foam::FixedList<T, Size>::FixedList(Foam::Istream&) [with T = int; unsigned int Size = 13]’ fileStat.C:114:33: required from here /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/typeInfo.H:91:5: warning: catching polymorphic type ‘class std::bad_cast’ by value [-Wcatch-value=] catch (std::bad_cast) ^~~~~ g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c POSIX.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/POSIX.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c cpuTime/cpuTime.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/cpuTime/cpuTime.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c clockTime/clockTime.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/clockTime/clockTime.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c cpuInfo/cpuInfo.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/cpuInfo/cpuInfo.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c memInfo/memInfo.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/memInfo/memInfo.o g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DFOAM_USE_INOTIFY -IlnInclude -I. -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/ef/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude -fPIC -c fileMonitor.C -o /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/fileMonitor.o In file included from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/PackedList.H:644, from fileMonitor.C:29: /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/PackedListI.H: In member function ‘void Foam::PackedList<nBits>::const_iterator::operator=(const Foam::PackedList<nBits>::iteratorBase&)’: /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/PackedListI.H:548:13: error: return-statement with a value, in function returning ‘void’ [-fpermissive] return *this; ^~~~ In file included from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/token.H:46, from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/UListIO.C:28, from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/UList.C:396, from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/UList.H:609, from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/List.H:43, from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/wordList.H:48, from /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/Enum.H:40, from fileMonitor.H:46, from fileMonitor.C:26: /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/typeInfo.H: In instantiation of ‘To& Foam::dynamicCast(From&) [with To = Foam::token::Compound<Foam::List<unsigned int> >; From = Foam::token::compound]’: /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/ListIO.C:60:13: required from ‘Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::List<T>&) [with T = unsigned int]’ /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/combineGatherScatter.C:466:27: required from ‘static void Foam::Pstream::listCombineScatter(const Foam::List<Foam::UPstream::commsStruct>&, Foam::List<T>&, int, Foam::label) [with T = unsigned int; Foam::label = int]’ /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/combineGatherScatter.C:526:9: required from ‘static void Foam::Pstream::listCombineScatter(Foam::List<T>&, int, Foam::label) [with T = unsigned int; Foam::label = int]’ fileMonitor.C:548:60: required from here /home/ef/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/typeInfo.H:91:5: warning: catching polymorphic type ‘class std::bad_cast’ by value [-Wcatch-value=] catch (std::bad_cast) ^~~~~ make: *** [/home/ef/OpenFOAM/OpenFOAM-v1712/wmake/rules/General/transform:29: /home/ef/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/fileMonitor.o] Error 1 I have no idea why/ what this means! Not having a lot of success finding anyone else with the same problem. I have successfully compiled on another machine using the same version of Fedora - the only think I can think of is that I somehow neglected to install some required package, though I can not figure out what it could be - the system is a pass on foamSystemCheck. Any ideas? thanks- |
June 20, 2018, 00:06 |
Abe
Rep Power: 9 |
This is so frustrating! I tried the the dev version and get a similar, but different error:
In file included from lnInclude/Reaction.H:431, from lnInclude/reactionTypes.H:36, from reaction/reactions/makeReactions.C:26: lnInclude/ReactionI.H: In member function ‘Foam::word& Foam::Reaction<ReactionThermo>::name()’: lnInclude/ReactionI.H:38:12: error: binding reference of type ‘Foam::word&’ to ‘const Foam::word’ discards qualifiers return name_; ^~~~~ make: *** [/home/ef/OpenFOAM/OpenFOAM-dev/wmake/rules/General/transform:26: /home/ef/OpenFOAM/OpenFOAM-dev/platforms/linux64GccDPInt32Opt/src/thermophysicalModels/specie/reaction/reactions/makeReactions.o] Error 1 Has anyone else had a similar problem? I am completely at a loss... |
June 20, 2018, 03:35 |
Abe
Rep Power: 9 |
In an act of desperation, I am even trying to install old versions of openfoam. I am getting similar errors. Does anyone know what this means:
/home/ef/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/FixedListIO.C:152:15: required from ‘Foam::FixedList<T, Size>::FixedList(Foam::Istream&) [with T = int; unsigned int Size = 13]’ fileStat.C:106:33: required from here /home/ef/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/typeInfo.H:91:5: warning: catching polymorphic type ‘class std::bad_cast’ by value [-Wcatch-value=] catch (std::bad_cast) ^~~~~ or this: Code:
In file included from /home/ef/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/PackedList.H:642, from fileMonitor.C:29: /home/ef/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/PackedListI.H: In member function ‘void Foam::PackedList<nBits>::const_iterator::operator=(const Foam::PackedList<nBits>::iteratorBase&)’: /home/ef/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/PackedListI.H:549:13: error: return-statement with a value, in function returning ‘void’ [-fpermissive] return *this; ^~~~ or this: Code:
/home/ef/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/combineGatherScatter.C:526:9: required from ‘static void Foam::Pstream::listCombineScatter(Foam::List<T>&, int, Foam::label) [with T = unsigned int; Foam::label = int]’ fileMonitor.C:553:60: required from here /home/ef/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/typeInfo.H:91:5: warning: catching polymorphic type ‘class std::bad_cast’ by value [-Wcatch-value=] catch (std::bad_cast) ^~~~~ make: *** [/home/ef/OpenFOAM/OpenFOAM-v1706/wmake/rules/General/transform:29: /home/ef/OpenFOAM/OpenFOAM-v1706/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/fileMonitor.o] Error 1 I compiled both these versions on previous versions of fedora without issue. Does anyone out there have a sucessful build on fedora 28? Could this be a bug? |
June 25, 2018, 16:39 |
Mark Olesen
Rep Power: 40 |
I understand how frustrating this type of errors can be, and the message really does sound like an error (programming, not compiler).
I've listed as an issue https://develop.openfoam.com/Develop...lus/issues/908 for follow up. If the problem is there it should certainly be fixed! If possible, please follow with some details (gcc version) on that issue. /mark |
June 26, 2018, 00:17 |
Abe
Rep Power: 9 |
Thanks for your reply and opening the issue. I ended up installing CentOS, building Cmake, and was able to compile without any issues. As an update to my previous threads, it turned out that both my installs failed, I just didn't notice at first. So it looks like a fedora related issue to me, though I could be wrong. Since you opened the issue, I will throw fedora on a virtual machine and see if I can recreate the error - might take me a while though. I am not sure what version of gcc it was, but being Fedora, I think it was the latest stable version available.
June 26, 2018, 00:51 |
Mark Olesen
Rep Power: 40 |
Thanks, could you also follow up via the issue, then the problem, solution, confirmation of the solution are documented - see new note there.
Should have been solved in the develop branch on 7-May https://develop.openfoam.com/Develop...ba83f81fa6ef37 perhaps you have checked out an older version of the develop branch. |
June 26, 2018, 03:52 |
tusabe
Rep Power: 7 |
Hi Mark,
I'm facing the same problem on Fedora 28... trying to compile v1712 from official website. So, if I understand it well, it will compile well using 7-May's branch? from where can I download it? Thank you! |
June 26, 2018, 04:06 |
Abe
Rep Power: 9 |
Hi Tusabe,
If you would like to post the error you are getting, it would be interesting to compare. |
June 26, 2018, 08:05 |
#9 |
Abe
Rep Power: 9 |
Here is the link to the latest versions for anyone with this problem:
https://www.openfoam.com/code/repositories.php |
June 26, 2018, 08:58 |
#10 |
tusabe
Rep Power: 7 |
The error after unpacking OpenFoam-v1712.tar.gz and ThirParty-v1712.tar.gz and issuing: cd $WM_PROJECT_DIR bin/tools/foamConfigurePaths -boost boost-system -cgal cgal-system -scotch scotch-system wmRefresh ./Allwmake are the following: In file included from /usr/include/c++/8/algorithm:60, from interface/../lib/partition/uncoarsening/separator/area_bfs.h:8, from interface/kaHIP_interface.cpp:32: /usr/include/c++/8/utility:149:12: error: partial specialization of ‘struct std::__is_tuple_like_impl<std:air<_T1, _T2> >’ after instantiation of ‘struct std::__is_tuple_like_impl<std:air<unsigned int, unsigned int> >’ [-fpermissive] struct __is_tuple_like_impl<std:air<_T1, _T2>> : true_type ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ make: *** [/opt/OpenFOAM/OpenFOAM-v1712/wmake/rules/General/transform:29: Make/linux64GccDPInt32Opt/interface/kaHIP_interface.o] Error 1 make: *** Waiting for unfinished jobs.... In file included from /usr/include/c++/8/tuple:38, from /usr/include/c++/8/bits/hashtable_policy.h:34, from /usr/include/c++/8/bits/hashtable.h:35, from /usr/include/c++/8/unordered_map:46, from /opt/OpenFOAM/ThirdParty-v1712/kahip-2.00/lib/partition/uncoarsening/refinement/quotient_graph_refinement/complete_boundary.h:27, from /opt/OpenFOAM/ThirdParty-v1712/kahip-2.00/lib/partition/uncoarsening/refinement/refinement.h:28, from /opt/OpenFOAM/ThirdParty-v1712/kahip-2.00/lib/partition/uncoarsening/refinement/kway_graph_refinement/kway_graph_refinement_commons.h:31, from /opt/OpenFOAM/ThirdParty-v1712/kahip-2.00/lib/partition/uncoarsening/refinement/kway_graph_refinement/kway_graph_refinement.h:30, from partition/initial_partitioning/initial_partition_bipartition.cpp:25: /usr/include/c++/8/utility:149:12: error: partial specialization of ‘struct std::__is_tuple_like_impl<std:air<_T1, _T2> >’ after instantiation of ‘struct std::__is_tuple_like_impl<std:air<unsigned int, unsigned int> >’ [-fpermissive] struct __is_tuple_like_impl<std:air<_T1, _T2>> : true_type ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ make: *** [/opt/OpenFOAM/OpenFOAM-v1712/wmake/rules/General/transform:29: Make/linux64GccDPInt32Opt/partition/initial_partitioning/initial_partition_bipartition.o] Error 1 Error building: kahip ... /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/typeInfo.H: In instantiation of ‘To& Foam::dynamicCast(From&) [with To = Foam::token::Compound<Foam::List<int> >; From = Foam::token::compound]’: /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/FixedListIO.C:173:13: required from ‘Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::FixedList<T, Size>&) [with T = int; unsigned int Size = 13]’ /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/FixedListIO.C:152:15: required from ‘Foam::FixedList<T, Size>::FixedList(Foam::Istream&) [with T = int; unsigned int Size = 13]’ fileStat.C:114:33: required from here /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/typeInfo.H:91:5: warning: catching polymorphic type ‘class std::bad_cast’ by value [-Wcatch-value=] catch (std::bad_cast) ^~~~~ ..... /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/PackedListI.H: In member function ‘void Foam::PackedList<nBits>::const_iterator:perator= (const Foam::PackedList<nBits>::iteratorBase&)’: /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/PackedListI.H:548:13: error: return-statement with a value, in function returning ‘void’ [-fpermissive] return *this; ^~~~ In file included from /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/token.H:46, from /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/UListIO.C:28, from /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/UList.C:396, from /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/UList.H:609, from /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/List.H:43, from /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/wordList.H:48, from /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/Enum.H:40, from fileMonitor.H:46, from fileMonitor.C:26: ... fileMonitor.C:548:60: required from here /opt/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude/typeInfo.H:91:5: warning: catching polymorphic type ‘class std::bad_cast’ by value [-Wcatch-value=] catch (std::bad_cast) ^~~~~ make: *** [/opt/OpenFOAM/OpenFOAM-v1712/wmake/rules/General/transform:29: /opt/OpenFOAM/OpenFOAM-v1712/build/linux64GccDPInt32Opt/src/OSspecific/POSIX/fileMonitor.o] Error 1 Hope this helps! Thank you. |
June 26, 2018, 09:11 |
#11 |
Abe
Rep Power: 9 |
Yeah, that looks like the same issue. Try pulling the latest from the above link. I haven't tried yet, but it should work since they fixed the bug on May 7th.
June 26, 2018, 09:34 |
#12 |
tusabe
Rep Power: 7 |
Hi!
Ok. Reading the information from this link, I'm a little bit confused: https://develop.openfoam.com/Develop...lus/issues/908 I believe that I have to pull this: https://develop.openfoam.com/Develop...f81fa6ef37.zip isn't it? Thank you! |
July 2, 2018, 16:19 |
#13 | |
Mark Olesen
Rep Power: 40 |
Probably easier just to grab the 1806 version now. |
November 16, 2020, 19:03 |
#14 |
NSW
I think it is caused by wrong gcc version.
March 16, 2021, 05:16 |
#15 |
Ashwani
Rep Power: 12 |
Had the same issue on Ubuntu v20. Fixed it by downgrading the gcc and g++ to version 7 from
sudo apt install g++-7 gcc-7 sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 7 sudo update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-7 7 sudo update-alternatives --config gcc sudo update-alternatives --config g++ Source: https://askubuntu.com/questions/1235...wer-than-gcc-7 |
July 7, 2021, 10:52 |
OpenFOAM-5 on ubuntu-20.04
#16 | |
Nima Samkhaniani
Rep Power: 24 |
This solution also works for installing OpenFOAM-5 in the ubuntu 20.04
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
