[OpenFOAM.org] OpenFoam5.x: recipe for target failed |
July 24, 2018, 18:41 |
#1 | |
Tony Zahtila
Rep Power: 10 |
Hi all,
I am building on Ubuntu making use of Windows subsystem for Linux. Any help appreciated. I have attached the full output text file Quote:
August 17, 2018, 14:28 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I'm somewhat late to this, but the problem is that LAM is the MPI toolbox that is being picked up by OpenFOAM when trying to build things, but LAM is not supported with the default installation options.
You should install Open-MPI (as instructed in the official installation instructions). If you have already installed it, then try running the following commands: Code:
foam ln -s /usr/bin/mpicc.openmpi bin/mpicc ln -s /usr/bin/mpirun.openmpi bin/mpirun wmRefresh
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
