[OpenFOAM.org] Problems installing OpenFOAM 2.3.1 in Ubuntu 12.04
Like Tree2Likes
  • 1 Post By mwaqas
  • 1 Post By alimea
Old   March 8, 2015, 05:03
Exclamation Problems installing OpenFOAM 2.3.1 in Ubuntu 12.04
Masoud
masoudshao is on a distinguished road
Dear Bruno,
I am using Ubuntu 12.04 LTS 64bit and I am trying to install openfoam 2.3.1. While testing the installation I got:
Third party software
Software Version   Location
flex     2.5.35    /usr/bin/flex
gcc      4.6.3     /usr/bin/gcc
gzip     1.4       /bin/gzip
tar      1.26      /bin/tar
icoFoam
WARNING:  Conflicting installations:
          OpenFOAM settings        : /home/masoud/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/icoFoam
          current path             :
          CRITICAL ERROR
Could you please help me solve this?
make.log.tar.gz
masoudshao is offline   Reply With Quote
Old   March 8, 2015, 07:39
Retired Super Moderator
Bruno Santos
Greetings Masoud and welcome to the forum!
I moved your post from the other thread, since the other one was for OpenFOAM 2.0.0.
I need to know something: how and when exactly did you install the MPI toolbox "LAM"?
I ask this because I'm not able to reproduce this problem with Ubuntu 12.04:
In file included from /usr/lib/lam/include/mpicxx.h:42:0,
                 from /usr/lib/lam/include/mpi.h:1128,
                 from ptscotchDecomp.C:125:
And because there was no problem when "libPstream" was built (it also depends on MPI)... which makes it even stranger!?
edit: Try running the following command:
sudo update-alternatives --set mpi /usr/lib/openmpi/include
The run Allwmake once again.
Best regards,
Bruno
Old   April 23, 2015, 06:28
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Dear Bruno,
I am trying to install OpenFoam-2.3.1. on ubuntu 12.04, I am already using OF-2.1.1. I want to install OF-2.3.1 in parallel with 2.1.1. I want to install 2.3.1 in Home/OpenFoam$. I followed your instructions as you mentioned in your instruction on: https://openfoamwiki.net/index.php/I...M-2.3.1/Ubuntu
When I run the command
source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc WM_NCOMPPROCS=4 WM_MPLIB=SYSTEMOPENMPII get following message
bash: /opt/OpenFOAM-2.3.1/bin/foamEtcFile: No such file or directory
bash: /opt/OpenFOAM-2.3.1/bin/foamCleanPath: No such file or directory
bash: /opt/OpenFOAM-2.3.1/etc/config/settings.sh: No such file or directory
bash: /opt/OpenFOAM-2.3.1/etc/config/aliases.sh: No such file or directory
Can you please tell me where I am making mistake and how can I install both version at the same time.
Regards
Kummi likes this.
mwaqas is offline   Reply With Quote
Old   April 23, 2015, 16:01
Bruno Santos
Quick answer - Please study this page: http://openfoamwiki.net/index.php/In...with_the_Shell - there you'll find details on how to have more than one OpenFOAM version installed.
Old   August 8, 2018, 02:32
A. Min
alimea is on a distinguished road
Originally Posted by mwaqas View Post
Dear Bruno,
Regards
Hi
I have this problem too.
Did you solve it?
Could you plz tell me how?
Thanks
alimea is offline   Reply With Quote
Old   August 8, 2018, 04:58
Muhammad Waqas
Hello Alimea,
It will be easier for me to reply if you could post your exact problem and what do you want to do.
As far as my problem was concerned, I wanted to have two different version of OF at the same time.
To have more than one version, one has to source the environment for each version by adding the following line in .baschr file
alias of5x='source $HOME/OpenFOAM/OpenFOAM-5.x/etc/bashrc WM_LABEL_SIZE=64 FOAMY_HEX_MESH=yes'
Then you have to enter "of5x" (in this above example), whenever you open a new terminal to use his particular version.
You could alias as many version as you want.
I hope it is not confusing
PS: To open .baschr file you can use following command in your home directory "gedit .baschr"
Regards
Old   August 8, 2018, 05:41
A. Min
Hello Alimea,
Regards
Dear Muhammad
Yes I have two versions of OF on my PC. but I had separated them with alias in bashrc before.
Old   August 8, 2018, 08:54
Muhammad Waqas
Dear Alimea,
You can have two version as I mentioned above.
If you have two versions and separated them with alias in baschr. What problem are you facing now?
Old   August 8, 2018, 09:44
A. Min
Dear Alimea,
As I mentioned in my last post, I need to install another version. Now It gave the error that is mentioned in your first message.
Old   August 9, 2018, 04:24
Muhammad Waqas
Hello alimea,
Ok, I am supposing you already have one version of OF in your machine (I guess it will be in home directory) and you want to install another one.
Do a fresh start with these steps.
1) Download 2nd version in you home directory which you want to install.
2) Source the environment by editing .baschr file. There should be alias command two times (for each version separately)
3) Type “source $HOME/.bashrc" in your terminal in home directory
4) Compile OF as you did for last installation.
About one thing I am not sure, I forgot. But you can try that if you face same error. When you open your terminal to source your environment. Before and/or after step 3 you can type alias command which you have used in .baschr file like "of5x" in post #6 example.
These were the steps, I used for my installation.
Regards
Old   August 9, 2018, 06:13
A. Min
Hello alimea,
Regards
Dear Muhammad
I solved the problem with deleting this line in my .bashrc file (in HOME directory):
“source /opt/.bashrc"
The recent version was "sourced" in .bashrc file. I deleted it and compile it correctly.
Thank you my friend
mwaqas likes this.
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
[OpenFOAM.org] Installing OpenFOAM 2.3 on Ubuntu 18.04 Joe1best OpenFOAM Installation 15 August 5, 2021 22:21
[foam-extend.org] Problems installing foam-extend-3.2 on Ubuntu 12.04 roenby OpenFOAM Installation 4 September 13, 2016 03:01
[waves2Foam] Problems in Operating waveDyMFoam in openfoam 2.3.1 zhxter OpenFOAM Community Contributions 2 May 18, 2015 20:57
Problems installing SVN in Ubuntu (for later installing PyFoam for OpenFOAM) immortality Lounge 2 May 24, 2014 03:05
