error in installation OpenFOAM 2.4.0 in Ubuntu 14.04
Hi foamers
I want to install OF2.4.0 on HOME directory of ubuntu 14.04 according to this address: https://openfoamwiki.net/index.php/I...u#Ubuntu_14.04 but it gave this error: http://uupload.ir/files/ae9_photo_20...8_12-53-28.jpg when I write this command: Code:
source $HOME/OpenFOAM/OpenFOAM-2.4.0/etc/bashrc WM_NCOMPPROCS=4 Thanks |
Hello
In fact you can see the problem in the err msg. You're sourcing: Code:
$HOME/OpenFOAM/OpenFOAM-2.4.0/etc/bashrc Code:
/opt/OpenFOAM-2.4.0/...... Either modify OF/etc/bashrc to set the correct path or move OF directory to /opt. I'd do the former. |
Dear Fatih I solved the problem with deleting this line in my .bashrc file (in HOME directory): Quote:
Thank you my friend |
