[OpenFOAM.com] OpenFOAM v2112 CGAL build fails - how to specify GMP library |
June 2, 2022, 06:14 |
Rep Power: 11 |
Hi
I am installing OFv2112 on RH8.3. I am Using the system compiler (gcc 8.5.0) and cmake (3.20.2). GMP, MPFR and MPC packages were also installed. The bashrc file specified the system compiler be used. Compilation generally went well (Allwmake), except issues were reported with CGAL as follows. Code:
-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -fPIC -O3 -DNDEBUG' -- USING LDFLAGS = '-m64 ' -- Configuring incomplete, errors occurred! See also "/fsx/apps/OpenFOAM/ThirdParty-v2112/build/linux64Gcc/CGAL-4.14.3/CMakeFiles/CMakeOutput.log". --------------------------------------------------- Optional component (CGAL) had build issues OpenFOAM will nonetheless remain largely functional --------------------------------------------------- Code:
== Setting paths == == Setting paths (DONE) == == Generate version files == == Generate version files (DONE) == == Detect external libraries == == Detect external libraries (DONE) == == Generating build files == Configuring libCGAL CMake Error at /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:230 (message): Could NOT find GMP (missing: GMP_LIBRARIES GMP_INCLUDE_DIR) Call Stack (most recent call first): /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE) cmake/modules/FindGMP.cmake:53 (find_package_handle_standard_args) cmake/modules/CGAL_SetupGMP.cmake:24 (find_package) cmake/modules/CGAL_SetupCGALDependencies.cmake:41 (include) src/CGAL/CMakeLists.txt:5 (include) How can I configure OF to build CGAL correctly and refer to the GMP libraries installed? The CGAL configure script appeared to only specify the GMP, MPC and MPFR version if the compiler variable is set to ThirdParty, mine is set to system. Thank you for any comments and advice. |
June 3, 2022, 12:38 |
Mark Olesen
Rep Power: 40 |
Should work fine with system gmp/mpfr - that's what I use all of the time (but on suse).
Make sure you have the gmp/mpfr-devel packages installed though. I'd guess they are missing on your system and it doesn't find any headers. |
June 6, 2022, 11:19 |
Rep Power: 11 |
Thank you Mark for the reply. A list of installed system packages filtered to those containing gmp and mpfr return the following.
sudo yum list installed | grep gmp gmp.x86_64 1:6.1.2-10.el8 @anaconda sudo yum list installed | grep mpfr mpfr.x86_64 3.1.6-1.el8 @anaconda I do not have the mpfr-devel package. Will try to install that and see what happens. |
June 6, 2022, 11:22 |
Rep Power: 11 |
Looks like installing the mpfr-devel package did the trick. Was able to run makeCGAL without error.
Will test properly in the next few days, and post back here. Many thanks for the suggestion. Last edited by asims; June 6, 2022 at 11:24. Reason: Unfinished |
June 16, 2022, 21:29 |
Simple test case run successfully
Rep Power: 11 |
Thank you for the response and suggestion. It looks like the installation is working OK now, and that installing that library solved the problem.
Thank you very much. |
June 20, 2022, 04:56 |
#6 | |
Mark Olesen
Rep Power: 40 |
Thanks for reporting back - this helps everyone. Too many forum users post questions, but never followup when the issue is solved. |
Display Modes | |
[OpenFOAM.org] Openfoam 2112 build fails with aocc and clang | NainaPatil | OpenFOAM Installation | 2 | April 22, 2022 14:59 |
How to develop OpenFOAM with CMake and popular IDEs | cosscholar | OpenFOAM Programming & Development | 0 | March 16, 2022 16:17 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
