[OpenFOAM.org] OpenFoam installation V6 on opensuse leap 15
Like Tree3Likes
Old   September 7, 2018, 14:35
Default OpenFoam installation V6 on opensuse leap 15
Stanley John
sjohn2 is on a distinguished road
Hi All,
I am trying to install openfoam v6 in opensuse leap 15.0 using the steps mentioned in the openfoam.org website
https://openfoam.org/download/6-linux/
Steps that worked are
uname -r
sudo zypper -n in docker
sudo systemctl start docker
sudo systemctl enable docker
sudo usr/bin/usermod -aG docker $(username)
sudo sh -c "wget http://dl.openfoam.org/docker/openfoam6-linux -O /usr/bin/openfoam6-linux"
sudo chmod 755 /usr/bin/openfoam6-linux
mkdir -p $HOME/OpenFOAM/${username}-6
cd $HOME/OpenFOAM/${username}-6
Everything is fine till now
when I run
openfoam6-linux
Launching /usr/bin/openfoam6-linux
User: "username" (ID ****, group ID **)
Welcome to the OpenFOAM v6 Docker Image
Provides bash terminal with OpenFOAM 6 and ParaView 5.4.0
Produced and maintained by CFD Direct (https://cfd.direct), on behalf of the
OpenFOAM Foundation (https://openfoam.org), the owner and distributor of
OpenFOAM as free, open source software under the General Public Licence v3.
Further Resources:
* OpenFOAM User Guide: https://cfd.direct/openfoam/user-guide
* C++ Source Guide: https://cpp.openfoam.org
* OpenFOAM Training: https://cfd.direct/openfoam-training
* Running in the Cloud: https://cfd.direct/cloud
* Issue (Bug) Reporting: https://bugs.openfoam.org
* Subscribe to Newsletter: https://cfd.direct/news
* Contributors to OpenFOAM: https://openfoam.org/dev/contributors
OpenFOAM-6(1)
The system hangs up at this stage
There is no error message or anything
Can you advise what is happening in the background? what must be the issue?
Thanks
Stanley
sjohn2 is offline   Reply With Quote
Old   September 11, 2018, 10:01
Stanley John
Anyone has any idea of this?
Old   September 14, 2018, 07:38
Retired Super Moderator
Bruno Santos
Quick answer: Please try running with the '-x' option, to see if it helps:
openfoam6-linux -x
If it doesn't work, I'll have to look into this more closely, to try and diagnose the issue.
Old   November 22, 2018, 11:17
Stanley John
Nopes it does not work
Stuck at the same step
When I install the source code too, I get an error
mpicc command not found
Old   December 27, 2018, 16:19
Bruno Santos
Greetings Stanley,
I've finally managed to test building OpenFOAM 6 on openSUSE 15.0 and I've written the instructions here: https://openfoamwiki.net/index.php/I...SUSE_Leap_15.0
The reason why you got the "mpicc" message was because Open-MPI is not ready to be used as soon as it's installed. You either have to log-out then log back in or have to source the script files that will load Open-MPI into the shell environment. This is instructed on the aforementioned wiki page
Best regards,
Bruno
Daniel_Khazaei and sjohn2 like this.
Old   January 1, 2019, 21:13
Default Thank you !
Stanley John
I am just starting my PhD at university of Alberta, Canada and we are trying to install openfoam from source code from few months now. I tried your steps and it worked ! I also noted that if I do
su instead of su -s to login as root, again I get the error that mpicc command not found.
After compiling openfoam, I was able to run a cavity tutorial and everything went well. However while post processing, I found that I am not able to use paraFoam, getting the following error. I have done the process of installinf paraview too mentioned in the wiki page. I am doing a remote login to do all this.
Created temporary 'cavity.OpenFOAM'
ParaView failed to open using available graphics hardware.
Trying fallback to software rendering using MESA.
/root/OpenFOAM/ThirdParty-6/platforms/linux64Gcc/ParaView-5.4.0/lib/paraview-5.4/paraview: symbol lookup error: /usr/lib64/libQtSql.so.4: undefined symbol: _ZN14QObjectPrivate15checkWindowRoleEv
Any idea?
Old   January 2, 2019, 19:25
Bruno Santos
Quick answer: My guess is that the big problem here is that you are running OpenFOAM and ParaView as root, which you should not be doing!!
Right there in step #3, it instructs to exit from root mode!! This is likely why things aren't working as intended
Old   January 2, 2019, 23:52
Talking
Stanley John
Yes I did forget to do it.
So I recompiled openfoam and third party software's the code locally, exiting root mode.
running
source /etc/profile.d/mpi-selector.sh
and of6 is the key here for me, otherwise I get the same error mpicc command not found
Able to run, icoFoam etc
but get the same error with interaction with paraview and graphics card
I also updated the driver for the graphics card to the latest nvidia graphics card
Old   January 3, 2019, 06:18
Default Not SUSE but...
Paul Johnston
paulj is on a distinguished road
When building on Centos I modified my .bashrc to load the open-mpi module adding
mpi/openmpi-x86_64
source /home/paulj/OpenFOAM/OpenFOAM-6/etc/bashrc
I loaded the module before building then kept it there.
Cheers Paul J
paulj is offline   Reply With Quote
Old   January 3, 2019, 10:27
Default Update
Stanley John
Thanks I added the two lines of step 4 in my bashrc file and all I do is source my bashrc file to run anything with openfoam
I tried 2 different ways of installing paraview locally
1) ./makeParaView -python -mpi -python-lib /usr/lib64/libpython2.7.so.1.0 > log.makePV 2>&1
on running paraFoam
error :
2) ./makeParaView > log.makePV2 2>&1
on running paraFoam
I/O : uncollated
paraFoam works fine!
Also I tried to run paraview by unzipping a rpm file available at opensuse website and running the executable, it works fine.
I think there a bug/ or some more steps are required while compiling paraview in third party.
Please find attached both log files.
Stanley
Old   January 4, 2019, 18:48
Bruno Santos
Quick answers:
@paulj:
mpi/openmpi-x86_64
I hope the first line is:
module load mpi/openmpi-x86_64
otherwise it's not going to work.
With openSUSE, it shouldn't be necessary to source "mpi-selector.sh" after logging out or at least after rebooting. It's a weird limitation that they have, for it to not propagate properly the functionality by simply allowing us to start a new terminal and having it work straight away.
@sjohn2:
on running paraFoam
error :
I'm suspecting that the instructions are not being followed to the letter ... because:
  1. The message in your latest post is still referring to being run as "root".
  2. The file "log.makePV" in the attached file has nothing to do with ParaView, given that it's referring to the output from running "ThirdParty-6/Allwmake".
on running paraFoam
I/O : uncollated
I'm glad it's finally working fine, even though it doesn't have Python and MPI working.
After some Googling for the other error, it seems possible that "libQtSql4.so" was installed from another repository and therefore be a mix of 2 different versions of Qt4, which lead to the original crash by ParaView... but it's weird, because it works in one build mode but not the other...
The instructions given in the page I found to diagnose the issue with Qt4 was as follows:
Please provide the output of:
rpm -qa libqt4*
Are you using additional repos?
zypper lr -d
Old   January 7, 2019, 11:10
Default results
  #12
Stanley John
I think I posted the wrong error text before. I had re installed Third Party software as local user and this the error I get. It is the same except without the root directory:
~/OpenFOAM/OpenFOAM-6/tutorials/incompressible/icoFoam/cavity/cavity> paraFoam
/home/sjohn2/OpenFOAM/ThirdParty-6/platforms/linux64Gcc/ParaView-5.4.0/lib/paraview-5.4/paraview: symbol lookup error: /usr/lib64/libQtSql.so.4: undefined symbol: _ZN14QObjectPrivate15checkWindowRoleEv
I have attached the results of the 2 commands you had listed
Old   January 8, 2019, 18:54
Bruno Santos
Quick answers:
  1. There are no clear signs of there being slightly different versions of "libQtSql.so.4" installed, given that the package versions indicated by the rpm command, are identical to the ones on my clean VM installation.
  2. I can't spot any inconsistencies with the repositories you are using in Zypper, at least no clear reason for Qt4 packages to be pulled from the wrong repository.
  3. I'm unable to deduce why this command:
    failed to provide a working build of ParaView, while without Python and MPI worked just fine, namely:
    ./makeParaView > log.makePV 2>&1
    • My best guess is that somehow the Python 2.7 or the MPI installations were somehow also using another Qt4 version for whatever weird reason...
  4. If I had access to the actual "log.makePV" that was created from this command:
    when built as normal user, I could then compare to the one on my build and with some luck be able to find a discrepancy on the build process... but without it, I'm just not seeing the breaking point
Old   January 9, 2019, 10:07
Default log file
  #14
Stanley John
The file is over 195 Kb limit after compressing using tar. I used 7z but apparently I cannot attach the particular format here. Any ideas how to upload it?
Old   January 9, 2019, 17:19
Bruno Santos
Quick answer: You can simply change the file extension and upload it here. As long as you tell us what's the real format, you can pretend it's a ".zip".
Old   January 10, 2019, 10:22
Default Link for file
  #16
Stanley John
Here's the google drive link, let me know if does not work for any reason
https://drive.google.com/file/d/1-JP...ew?usp=sharing
Old   January 10, 2019, 16:16
Bruno Santos
Greetings Stanley,
Ah HA! It's ANSYS fault
At around line 2200 of the log file we can see this:
CMake Warning at VTK/CMake/vtkModuleMacros.cmake:548 (add_library):
  Cannot generate a safe runtime search path for target
  vtkPVVTKExtensionsRendering because files in some directories may conflict
  with libraries in implicit directories:
    runtime library [libQtGui.so.4] in /usr/lib64 may be hidden by files in:
      /ansys_inc/v191/Framework/bin/Linux64
    runtime library [libQtCore.so.4] in /usr/lib64 may be hidden by files in:
and only stops complaining about it at around line 3069.
Then near the end of the log are lines like this one:
-- Set runtime path of "/home/sjohn2/OpenFOAM/ThirdParty-6/platforms/linux64Gcc/ParaView-5.4.0/lib/paraview-5.4/paraview" to "/usr/lib64/mpi/gcc/openmpi/lib64:/ansys_inc/v191/Framework/bin/Linux64"
So this is the real problem and why ParaView is not working properly. It has used the local system's Qt4 include files, but then it links to the Qt4 libraries in ANSYS, but even then it tries running ParaView with the system's Qt4 version... so yeah, this was the problem.
OK, so how to solve this... the simplest solution would be to depends on how the ANSYS v19.1 paths are being loaded into the shell variables "PATH" and "LD_LIBRARY_PATH" and deactivate that from being loaded into the shell environment, at least while you are building ParaView.
But if you don't know where that was defined to comment it out and then start a new terminal, then we will have to go the other way around and remove those paths from "PATH" and "LD_LIBRARY_PATH"... OK, if I'm not mistaken, run the following commands before running makeParaView:
export PATH=$(foamCleanPath "$PATH" "/ansys_inc/v191")
export LD_LIBRARY_PATH=$(foamCleanPath "$LD_LIBRARY_PATH" "/ansys_inc/v191")
These commands will use OpenFOAM's path cleaning script and therefore remove anything that starts with said main path for ANSYS v191.
If all goes well, after you've rebuilt ParaView, it should work as intended. Oh, then don't forget to run the commands for rebuilding the OpenFOAM readers for ParaView, in the same terminal where you build ParaView:
wmRefresh
cd $FOAM_UTILITIES/postProcessing/graphics/PVReaders
./Allwclean
./Allwmake
Best regards,
Bruno
Old   January 10, 2019, 18:33
Stanley John
Cheers mate! ParsFoam works fine!
Many Thanks
wyldckat likes this.
Old   July 12, 2019, 17:17
Stanley John
Is pyFoam also installed along with this?
I cannot do PyFoam after starting python
Old   July 13, 2019, 17:25
Bruno Santos
Instructions for installing PyFoam with Python+Pip are provided here: https://openfoamwiki.net/index.php/C...lling_with_pip
opensuse
[Other] Installation of OpenFOAM: Docker or not Docker? zt49 OpenFOAM Installation 2 December 22, 2016 10:38
[OpenFOAM.org] OpenFOAM 2.1.1 installation on openSUSE 12.2 32 bit saturn_53 OpenFOAM Installation 13 February 1, 2015 04:17
OpenFOAM 1.7.0 on OpenSUSE 11.1 Bufacchi OpenFOAM Installation 8 August 6, 2010 09:57
OpenFOAM 1.5 installation on OpenSUSE 11.0 bigphil OpenFOAM Installation 16 April 29, 2009 06:28
OpenFOAM 1.5-dev installation in OpenSuSe 10.3 darenyang OpenFOAM Installation 0 April 28, 2009 04:30
