[OpenFOAM.org] Issues installing openfoam 6 on Ubuntu 18.04
Like Tree1Likes
  • 1 Post By rnburne
Old   October 20, 2018, 11:33
Default Issues installing openfoam 6 on Ubuntu 18.04
Ron Burnett
rnburne is on a distinguished road
I'm upgrading to openfoam 6 on a newly installed Ubuntu 18.04.1
using the instructions at openfoam.org, which have worked well
in the past.
In response to the following commands.......
sudo sh -c "wget -O - http://dl.openfoam.org/gpg.key | apt-key add -"
sudo add-apt-repository http://dl.openfoam.org/ubuntu
I get..........
r@sys:~$ sudo apt-get update
Hit:1 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Hit:2 http://archive.canonical.com/ubuntu bionic InRelease
Get:3 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Get:5 http://security.ubuntu.com/ubuntu bionic-security InRelease [83.2 kB]
Get:4 http://dl.openfoam.org/ubuntu bionic InRelease [6,337 B]
Get:6 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Reading package lists... Done
E: Release file for http://us.archive.ubuntu.com/ubuntu/...ates/InRelease is not valid yet (invalid for another 1h 50min 44s). Updates for this repository will not be applied.
E: Release file for http://dl.openfoam.org/ubuntu/dists/bionic/InRelease is not valid yet (invalid for another 2h 35min 9s). Updates for this repository will not be applied.
E: Release file for http://security.ubuntu.com/ubuntu/di...rity/InRelease is not valid yet (invalid for another 1h 50min 33s). Updates for this repository will not be applied.
E: Release file for http://us.archive.ubuntu.com/ubuntu/...orts/InRelease is not valid yet (invalid for another 1h 51min 9s). Updates for this repository will not be applied.
While not understanding the message, I went ahead and updated.......
Hit:1 http://archive.canonical.com/ubuntu bionic InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Get:2 http://security.ubuntu.com/ubuntu bionic-security InRelease [83.2 kB]
Hit:8 http://us.archive.ubuntu.com/ubuntu xenial InRelease
Get:7 http://dl.openfoam.org/ubuntu bionic InRelease [6,337 B]
Get:4 http://security.ubuntu.com/ubuntu xenial-security InRelease [107 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Get:9 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease [107 kB]
Get:10 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB]
E: Release file for http://security.ubuntu.com/ubuntu/di...rity/InRelease is not valid yet (invalid for another 1h 25min 1s). Updates for this repository will not be applied.
E: Release file for http://dl.openfoam.org/ubuntu/dists/bionic/InRelease is not valid yet (invalid for another 2h 9min 37s). Updates for this repository will not be applied.
E: Release file for http://security.ubuntu.com/ubuntu/di...rity/InRelease is not valid yet (invalid for another 1h 25min 39s). Updates for this repository will not be applied.
E: Release file for http://us.archive.ubuntu.com/ubuntu/...ates/InRelease is not valid yet (invalid for another 1h 25min 12s). Updates for this repository will not be applied.
E: Release file for http://us.archive.ubuntu.com/ubuntu/...orts/InRelease is not valid yet (invalid for another 1h 25min 38s). Updates for this repository will not be applied.
E: Release file for http://us.archive.ubuntu.com/ubuntu/...orts/InRelease is not valid yet (invalid for another 1h 27min 37s). Updates for this repository will not be applied.
E: Release file for http://us.archive.ubuntu.com/ubuntu/...ates/InRelease is not valid yet (invalid for another 1h 52min 46s). Updates for this repository will not be applied.
And tried the install command.........
r@sys:~$ sudo apt-get -y install openfoam6
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 openfoam6 : Depends: libreadline-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Can anyone figure this out?
Ron
Last edited by wyldckat; October 20, 2018 at 16:09. Reason: Added [CODE][/CODE] markers
rnburne is offline   Reply With Quote
Old   October 20, 2018, 16:12
Retired Super Moderator
Bruno Santos
Quick answer: I've Google'd for:
ubuntu "Release file for"  "is not valid yet"
and it seems that the problem is that your machine clock is ahead of time for a few hours, hence the message that the release file is not valid yet...
As far as I can figure out, this is a safety measure to avoid machines using a repository that is still syncing up with another server.
Allegedly:
  • Either you change how the clock is defined in your machine, namely by telling it to use NTP (the option is named something like "automatically defined with Internet clock") or run the following command:
    sudo timedatectl set-ntp on
  • Or you change the current clock time manually, install OpenFOAM et al and the set the clock back to the desired time.
Old   October 20, 2018, 17:29
Ron Burnett
That was indeed the case........I had the correct
local time but the wrong time zone.
The installation is working properly, thank you
for the help Bruno.
Ron
wyldckat likes this.
[waves2Foam] waves2Foam on an Ubuntu 18.04 with OpenFOAM 1712 JGadelho OpenFOAM Community Contributions 35 November 6, 2023 12:42
Installing OpenFOAM 2.2.0 on Ubuntu 12.10 i686 AHutchison OpenFOAM Installation 6 June 4, 2013 13:11
Installing OpenFOAM 1.6-ext on Ubuntu 11.10 immortality OpenFOAM Installation 17 May 6, 2013 18:43
Gettings started after installing OpenFOAM 2.1.1 in Ubuntu 12.10 yoddha24 OpenFOAM 7 November 22, 2012 12:46
Trouble with installing OpenFOAM on Ubuntu Milos OpenFOAM Installation 16 November 16, 2009 03:44
