[OpenFOAM.org] install openfoam 2.4.x,Target `application' not remade because of errors
Like Tree2Likes
  • 1 Post By svinaya
  • 1 Post By himanshu28
Old   December 20, 2016, 02:29
Default install openfoam 2.4.x,Target `application' not remade because of errors
vin
svinaya is on a distinguished road
Dear All,
Can U please help me installing Iam getting these error in the log file.
Making dependency list for source file heatTransferModels/heatTransferModel/newHeatTransferModel.C
Making dependency list for source file heatTransferModels/RanzMarshall/RanzMarshall.C
-lcompressibleTurbulenceModels -lphaseCompressibleTurbulenceModels -lincompressibleTransportModels -lcompressibleTwoPhaseSystem -lcompressibleEulerianInterfacialModels -lfiniteVolume -lfvOptions -lmeshTools -lsampling -lOpenFOAM -ldl -lm -o /home/vinayas/OpenFOAM/OpenFOAM-2.4.x/platforms/linux64Gcc48DPOpt/bin/twoPhaseEulerFoam
/usr/bin/ld: cannot find -lfluidThermophysicalModels
collect2: ld returned 1 exit status
make[2]: *** [/home/vinayas/OpenFOAM/OpenFOAM-2.4.x/platforms/linux64Gcc48DPOpt/bin/twoPhaseEulerFoam] Error 1
make[1]: *** [twoPhaseEulerFoam] Error 2
make[1]: Target `application' not remade because of errors.
make: *** [multiphase] Error 2
make: Target `application' not remade because of errors.
with kind regards
vinaya
svinaya is offline   Reply With Quote
Old   December 20, 2016, 19:13
Retired Super Moderator
Bruno Santos
Quick questions:
  1. Which Linux Distribution are you using?
  2. Which installation instructions are you following?
  3. Can you provide the complete log file?
Old   December 20, 2016, 23:15
vin
Thank U for the quick response.
I tried once again installing OpenFoam 2.4.x and followed the instructions.
Itz working fine.
With kind regards,
Vinaya
wyldckat likes this.
Old   January 21, 2017, 14:49
Default Same error as posted in the Thread
Himanshu Sharma
himanshu28 is on a distinguished road
Originally Posted by wyldckat View Post
Quick questions:
Hi wyldckat,
I am getting the same error as posted earlier message. I am also trying to install OpenFOAM-2.4.0
I have attached my log.make file with the post.
1) Red Hat Enterprise Linux Workstation release 7.3 (Maipo)
2) Following instructions from:
https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL
(CentOS 7.1)
3) Log file not able to attached here (exceed upload limit) hence shared on drive.
(https://drive.google.com/open?id=0B8...0FRRm1LMlpTU1k)
Thank you
himanshu28 is offline   Reply With Quote
Old   March 25, 2017, 16:07
Bruno Santos
Greetings Himanshu,
My apologies for the really late answer, but only now did I finally manage to take a look into this.
From what I can figure out, the problem is that you tried to run the command Allwmake with the option "-j". The problem is that this option was only introduced starting with OpenFOAM 3.0.0.
Furthermore, this option confuses the scripts in OpenFOAM 2.4.0, because they are expecting something else.
I don't know why exactly you used that option, because the instructions on the wiki page that you pointed out - https://openfoamwiki.net/index.php/I...HEL#CentOS_7.1 - specifically state how to define the number of cores for building in parallel in step #8. In addition, on step #11, it does not instruct to use "-j".
I'm hoping that you solved this issue by following again this section on the wiki page.
Best regards,
Bruno
Old   March 25, 2017, 16:56
Himanshu Sharma
Greetings Himanshu,
Best regards,
Bruno
Thanks for the inputs Bruno. I actually installed OF-4.0 and that pretty much solved the Error.
Old   November 15, 2018, 06:25
caoxuxiang's Avatar
Xuxiang Cao
caoxuxiang is on a distinguished road
Originally Posted by svinaya View Post
Dear All,
with kind regards
vinaya
I had the same problem with you when i installed of-2.4.0.
Bruno is right.
It does not instruct to use "-j".
Just "./Allwmake".
best regards.
Xuxiang
caoxuxiang is offline   Reply With Quote
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 15:53
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
