[OpenFOAM.com] Installation on Virtual Machine
Old   December 5, 2018, 06:26
Default [SOLVED] Installation on Virtual Machine
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am running Windows 7 and I'd like to install OpenFOAM.
To you, which is the best way to proceed? Could a virtual machine be a good choice?
Any advice?
Thanks a lot,
samiam1000 is offline   Reply With Quote
Old   December 5, 2018, 08:18
Pekka Pasanen
zordiack is on a distinguished road
I would suggest that you create a virtual machine and install Linux and OpenFOAM in there. Almost any modern Linux distribution should work, distribution selection is more of a matter of taste and topic of another discussion If you are unfamiliar with Linux in general, anything Debian based should have pretty good online support and easy package management.
There is no official native build on Windows, Openfoam.com releases a Bash on Ubuntu in version of OpenFOAM, but it is basically also a virtual machine. My personal preference is to use my own VM so I'm not limited to release versions. There's also a firm called BlueCape, which used to make native builds of OpenFOAM for Windows, but I don't know if they still do.
For testing and learning a VM should be pretty usable, but of course you will lose performance because of virtualization if you start to make more demanding simulations. You will also need to divide your RAM between host and quest, which might be a limiting factor depending on hardware setup.
Anyway, I think a virtual machine is a good way to get used to OpenFOAM if you must have Windows as a operating system.
zordiack is offline   Reply With Quote
Old   December 5, 2018, 08:28
Samuele Z
Great analysis: thanks a lot!
Old   December 5, 2018, 08:58
Alberto
malv83 is on a distinguished road
The BlueCAPE software (BlueCFD-core) is an excellent option for running OpenFOAM on windows. I have been using the BlueCFD-core 2017-2 for over a year now with no issues on Windows 7. It has full functionalities from OpenFOAM 5.x (at least I have not had any problems with it).
Here is the link: http://bluecfd.github.io/Core/
malv83 is offline   Reply With Quote
[TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines ghost82 FLUENT 54 February 9, 2022 03:32
[Other] Support for the USB-stick image and Virtual Machine Appliance for the OFW11 wyldckat OpenFOAM Installation 2 August 7, 2016 17:50
speedup when moving from virtual machine to physical mpeti OpenFOAM Running, Solving & CFD 0 October 18, 2011 10:38
OpenFOAM 1.6 virtual machine mahaputra OpenFOAM Installation 4 October 30, 2009 03:01
OpenFOAM Distribution by Virtual Machine will OpenFOAM Installation 5 June 20, 2008 08:11
