[OpenFOAM.com] OpenFOAMv1806 with amd aocc 1.2 / 1.3 compiler |
December 5, 2018, 11:16 |
davide
Rep Power: 8 |
Hi
I am trying to compile OpenFOAM v1806 with AMD compilers (AOCC v 1.2.1 and 1.3.0) for an AMD Epyc processor platform. The OS is Centos 7.5, open-mpi 3.1.3, gcc 7.3.1, clang 7.0.0 (for AOCC 1.3) and clang 6.0 (AOCC 1.2.1). I get multiple errors during compilation (./Allwmake) with AOCC v 1.3. The first error encountered is: Code:
In file included from buoyantBoussinesqPimpleFoam.C:62: In file included from /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/src/OpenFOAM/lnInclude/postProcess.H:131: ../buoyantBoussinesqSimpleFoam/createFields.H:107:5: error: use of undeclared identifier 'simple'; did you mean 'pimple'? simple.dict(), ^~~~~~ pimple /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/src/finiteVolume/lnInclude/createPimpleControl.H:1:15: note: 'pimple' declared here pimpleControl pimple(mesh); ^ In file included from coldEngineFoam.C:50: In file included from /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/src/OpenFOAM/lnInclude/postProcess.H:131: ../XiFoam/createFields.H:3:9: error: use of undeclared identifier 'psiuReactionThermo' autoPtr<psiuReactionThermo> pThermo ^ ../XiFoam/createFields.H:7:1: error: unknown type name 'psiuReactionThermo' psiuReactionThermo& thermo = pThermo(); ^ ../XiFoam/createFields.H:7:30: error: use of undeclared identifier 'pThermo' psiuReactionThermo& thermo = pThermo(); ^ ../XiFoam/createFields.H:10:1: error: unknown type name 'basicSpecieMixture' basicSpecieMixture& composition = thermo.composition(); ^ ../XiFoam/createFields.H:78:9: error: use of undeclared identifier 'laminarFlameSpeed' autoPtr<laminarFlameSpeed> unstrainedLaminarFlameSpeed ^ 5 errors generated. make[2]: *** [/cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/wmake/rules/General/transform:35: /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/build/linux64ClangDPInt32Opt/applications/solvers/combustion/coldEngineFoam/coldEngineFoam.o] Error 1 make[1]: *** [/cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/wmake/makefiles/apps:27: coldEngineFoam] Error 2 make[1]: *** Waiting for unfinished jobs.... Code:
/cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/src/finiteVolume/lnInclude/createRDeltaT.H:1:16: error: no member named 'localEulerDdt' in namespace 'Foam::fv' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/src/finiteVolume/lnInclude/createRDeltaT.H:15:21: error: no member named 'localEulerDdt' in namespace 'Foam::fv' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/combustion/reactingFoam/createFields.H:4:9: error: unknown type name 'psiReactionThermo'; did you mean 'rhoReactionThermo'? /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/combustion/reactingFoam/createFields.H:4:36: error: use of undeclared identifier 'psiReactionThermo'; did you mean 'rhoReactionThermo'? /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/combustion/reactingFoam/createFields.H:5:1: error: unknown type name 'psiReactionThermo'; did you mean 'rhoReactionThermo'? /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/combustion/reactingFoam/createFields.H:48:1: error: unknown type name 'pressureControl' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/combustion/reactingFoam/createFields.H:48:41: error: use of undeclared identifier 'pimple'; did you mean 'simple'? /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/combustion/reactingFoam/createFields.H:65:25: error: use of undeclared identifier 'psiReactionThermo' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/combustion/reactingFoam/createFields.H:68:2: error: expected a type /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/multiphase/interPhaseChangeFoam/createFields.H:33:9: error: use of undeclared identifier 'phaseChangeTwoPhaseMixture' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/multiphase/interPhaseChangeFoam/createFields.H:36:24: error: use of undeclared identifier 'mixture' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/multiphase/interPhaseChangeFoam/createFields.H:37:24: error: use of undeclared identifier 'mixture' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/multiphase/interPhaseChangeFoam/createFields.H:39:33: error: use of undeclared identifier 'mixture' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/multiphase/interPhaseChangeFoam/createFields.H:40:33: error: use of undeclared identifier 'mixture' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/multiphase/interPhaseChangeFoam/createFields.H:59:42: error: use of undeclared identifier 'mixture' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/applications/solvers/multiphase/interPhaseChangeFoam/createFields.H:64:50: error: use of undeclared identifier 'mixture' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/src/finiteVolume/lnInclude/createRDeltaT.H:1:16: error: no member named 'localEulerDdt' in namespace 'Foam::fv' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/src/finiteVolume/lnInclude/createRDeltaT.H:15:21: error: no member named 'localEulerDdt' in namespace 'Foam::fv' ../interFoam/createFields.H:35:1: error: unknown type name 'immiscibleIncompressibleTwoPhaseMixture' ../interFoam/createFields.H:75:9: error: use of undeclared identifier 'incompressible'; did you mean 'compressible'? ../interFoam/createFields.H:77:5: error: use of undeclared identifier 'incompressible'; did you mean 'compressible'? /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/src/finiteVolume/lnInclude/createFvOptions.H:1:28: error: no member named 'options' in namespace 'Foam::fv' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/src/finiteVolume/lnInclude/createFvOptions.H:1:5: error: no member named 'options' in namespace 'Foam::fv' /cluster/software/OpenFOAM/of1806_aocc13/OpenFOAM-v1806_aocc13/src/finiteVolume/lnInclude/createFvOptions.H:3:6: error: use of undeclared identifier 'fvOptions' Code:
ld.lld: error: unknown argument: --add-needed clang-7: error: linker command failed with exit code 1 (use -v to see invocation) clang -v Code:
AOCC.LLVM.1.3.0.B34.2018_10_22 clang version 7.0.0 (CLANG: Jenkins AOCC_1_3_0_Release-Build#34) (based on LLVM AOCC.LLVM.1.3.0.B34.2018_10_22) Target: x86_64-unknown-linux-gnu Thread model: posix InstalledDir: /cluster/software/aocc-1.3.0/AOCC-1.3.0-Compiler/bin Found candidate GCC installation: /opt/rh/devtoolset-7/root/usr/lib/gcc/x86_64-redhat-linux/7 Found candidate GCC installation: /usr/lib/gcc/x86_64-redhat-linux/4.8.2 Found candidate GCC installation: /usr/lib/gcc/x86_64-redhat-linux/4.8.5 Selected GCC installation: /opt/rh/devtoolset-7/root/usr/lib/gcc/x86_64-redhat-linux/7 Candidate multilib: .;@m64 Candidate multilib: 32;@m32 Selected multilib: .;@m64 Code:
gcc -v Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/opt/rh/devtoolset-7/root/usr/libexec/gcc/x86_64-redhat-linux/7/lto-wrapper Target: x86_64-redhat-linux Configured with: ../configure --enable-bootstrap --enable-languages=c,c++,fortran,lto --prefix=/opt/rh/devtoolset-7/root/usr --mandir=/opt/rh/devtoolset-7/root/usr/share/man --infodir=/opt/rh/devtoolset-7/root/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-gcc-major-version-only --enable-plugin --with-linker-hash-style=gnu --enable-initfini-array --with-default-libstdcxx-abi=gcc4-compatible --with-isl=/builddir/build/BUILD/gcc-7.3.1-20180303/obj-x86_64-redhat-linux/isl-install --enable-libmpx --enable-gnu-indirect-function --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux Thread model: posix gcc version 7.3.1 20180303 (Red Hat 7.3.1-5) (GCC) I tried already to delete from wmake/rules/linux64Clang/c and c++ Code:
-Xlinker --add-needed The compilation with AOCC 1.2.1 (clang 6.0) gives similar results Am i making a mistake? Any idea what is going? Thank you in advance for any suggestion! P.s.: I compiled of1806 on the same machine with gcc 7.3.1 without problems. |
December 9, 2018, 05:21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I don't know if they have been building with clang in their tests, but they will likely be interested in this, so please report this problem at their issue tracker: https://develop.openfoam.com
December 20, 2018, 13:38 |
#3 | |
Mark Olesen
Rep Power: 40 |
This is an interesting one. We generally build with gcc 4.8.5, gcc-7.3.1 and clang 4 on a regular basis and intel on a less regular basis, but have keep a slight distance from the newer llvm versions. The clang compilers are really good (very picky) about picking up non-standard or slightly question constructions, but in other places the optimizer has removed conditionals that it thinks it doesn't need - resulting in a region of code being improperly initialized. This might need some more investigation. Please open a gitlab issue for tracking it. Cheers, /mark |
December 20, 2018, 19:20 |
Mark Olesen
Rep Power: 40 |
Just compiled through OpenFOAM-v1812 using clang 7.0.0 without needing to change anything.
I wonder if this was something that has been fixed in OpenFOAM since 1806, or if the AOCC is doing something different. |
January 2, 2019, 01:50 |
davide
Rep Power: 8 |
Hi Mark
I ll give it a try with OpenFOAM 1812 and AOCC 1.2 . If the problems persist, I will open a gitlab issue. |
February 12, 2019, 01:53 |
#6 | |
Rep Power: 7 |
OpenFOAM sources : 1812 AoCC compiler : 1.3.0 - OpenFOAM 1812 patch fix resolution to be built with AoCC compiler 1.3.0: >> File : OpenFOAM-v1812/etc/bashrc -------------------------------------------------------------------------------------- +export WM_COMPILER=Clang File : OpenFOAM-v1812/wmake/rules/linux64Clang/c++ -------------------------------------------------------------------------------------- +CC = clang++ -std=c++11 -m64 -fopenmp +LINKEXE = $(CC) -fuse-ld=ld -Wl,-add-needed File : OpenFOAM-v1812/wmake/rules/linux64Clang/c -------------------------------------------------------------------------------------- +cc = clang -m64 -fopenmp +cFLAGS = $(GFLAGS) $(cWARN) $(cOPT) $(cDBUG) $(LIB_HEADER_DIRS) -fPIC +LINKEXE = $(cc) -fuse-ld=ld -Wl,-add-needed File : ThirdParty-v1812/scotch_6.0.6/src/Make.inc/Makefile.inc.x86-64_pc_linux2 -------------------------------------------------------------------------------------- +AR = clang +ARFLAGS = $(WM_CFLAGS) -shared -fPIC -o +CCS = clang +CCD = mpicc +CFLAGS = $(WM_CFLAGS) -O3 -fPIC -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -DSCOTCH_PTHREAD -Drestrict=__restrict -DIDXSIZE64 CLIBFLAGS = +LDFLAGS = -lz -lm -lrt -pthread -Wl,-z,notext -fPIC << - The issue is due to the deprecated “-Wl,-add-needed” flag which currently not supported by lld. - Here the AOCC-1.3.0 with internal ld.lld [ AoCC provided LLD 1.3.0 ], does not support the deprecated "--add-needed" flag and by using the “-fuse-ld=ld -Wl,-add-needed”, the AOCC-1.3.0 tool chain successfully builds the OpenFOAM 1812 sources. - By default llvm-7.0.1 uses the system linker which supports this flag and hence it builds the OpenFOAM 1812 sources. Note : - In addition to above, you can try out the flag “-march=znver1” for OpenFOAM optimization. |
February 12, 2019, 06:16 |
davide
Rep Power: 8 |
The link to the patch fix is not active. Could you post it again please?
February 18, 2019, 03:37 |
#8 | |
Rep Power: 7 |
filename : OpenFOAM-1812_patch_diff_fix_AoCC-1.3.0.patch 2. Steps to patch and build OpenFOAM 1812 sources using AoCC 1.3.0 compiler, >> mkdir ~/1812_patched cp ~/OpenFOAM-v1812.tgz ~/1812_patched cp ~/ThirdParty-v1812.tgz ~/1812_patched cd ~/1812_patched tar xfz OpenFOAM-v1812.tgz tar xfz ThirdParty-v1812.tgz cd ~/ patch -p0 --follow-symlinks -i OpenFOAM-1812_patch_diff_fix_AoCC-1.3.0.patch source ~/compiler/AOCC/release/1.3/setenv_AOCC.sh echo "Set Compiler Settings " unset C_INCLUDE_PATH unset CPLUS_INCLUDE_PATH # Set up OpenMPI to use AOCC export PATH=/usr/lib64/openmpi/bin/:$PATH export LD_LIBRARY_PATH=/usr/lib64/openmpi/lib/:$LD_LIBRARY_PATH export OMPI_CC=clang export OMPI_CXX=clang++ export OMPI_FC=flang cd ~/1812_patched source OpenFOAM-v1812/etc/bashrc echo $WM_PROJECT_DIR cd $WM_PROJECT_DIR time ./Allwmake -j 64 all -k &> buildOpenFOAM_AoCC-1.3.log & << 3. Additionally, you can find additional resources and post queries related to AMD Optimizing C/C++ Compiler at link : https://community.amd.com/community/devgurus Feel free to ask any further information. Last edited by RaghavendraSwamyH; February 19, 2019 at 04:51. |
February 21, 2019, 04:23 |
davide
Rep Power: 8 |
Thank you very much for the detailed instructions.
I followed your instructions but could not compile OF1812 successfully. I get the following errors (all during the compilation of cfmesh) and a couple of warnings: Code:
utilities/meshes/polyMeshGen/polyMeshGenFacesI.H:29:10: fatal error: 'omp.h' file not found Code:
[0] #[1] #[3] #0 [4] #0 0 0 Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)[2] #0 Foam::error::printStack(Foam::Ostream&)-------------------------------------------------------------------------- A process has executed an operation involving a call to the "fork()" system call to create a child process. Open MPI is currently operating in a condition that could result in memory corruption or other system errors; your job may hang, crash, or produce silent data corruption. The use of fork() (or system() or other calls that create child processes) is strongly discouraged. The process that invoked fork was: Local host: [[2745,1],4] (PID 59592) If you are *absolutely sure* that your application will successfully and correctly survive a call to fork(), you may disable this warning by setting the mpi_warn_on_fork MCA parameter to 0. -------------------------------------------------------------------------- [5] #0 Foam::error::printStack(Foam::Ostream&) at ??:? at at at ??:? ??:? ??:? at at [1] #1 ??:? ??:? Foam::sigFpe::sigHandler(int)[4] #1 Foam::sigFpe::sigHandler(int)[5] #1 [2] #1Foam::sigFpe::sigHandler(int) Foam::sigFpe::sigHandler(int)[3] #1 Foam::sigFpe::sigHandler(int)[0] #1 Foam::sigFpe::sigHandler(int) at ??:? [3] #2 ? at ??:? [5] #2 ? at ??:? [0] at #2 ???:? [1] #2 ? at at ??:? [2] #2 ??:? ?[4] #2 ? in /usr/lib64/libpthread.so.0 [3] #3 Foam::polyMeshGeometry::checkCellDeterminant(bool, double, Foam::polyMesh const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::HashSet<int, Foam::Hash<int> >*) in /usr/lib64/libpthread.so.0 [5] #3 Foam::polyMeshGeometry::checkCellDeterminant(bool, double, Foam::polyMesh const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::HashSet<int, Foam::Hash<int> >*) in /usr/lib64/libpthread.so.0 [1] #3 Foam::polyMeshGeometry::checkCellDeterminant(bool, double, Foam::polyMesh const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::HashSet<int, Foam::Hash<int> >*) in /usr/lib64/libpthread.so.0 [4] #3 Foam::polyMeshGeometry::checkCellDeterminant(bool, double, Foam::polyMesh const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::HashSet<int, Foam::Hash<int> >*) in /usr/lib64/libpthread.so.0 [0] #3 in Foam::polyMeshGeometry::checkCellDeterminant(bool, double, Foam::polyMesh const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::HashSet<int, Foam::Hash<int> >*)/usr/lib64/libpthread.so.0 [2] #3 Foam::polyMeshGeometry::checkCellDeterminant(bool, double, Foam::polyMesh const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int> const&, Foam::List<int> const&, Foam::HashSet<int, Foam::Hash<int> >*) at ??:? at [0] #4 at ??:? Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::List<int> const&, Foam::List<Foam::Pair<int> > const&, Foam::HashSet<int, Foam::Hash<int> >&) at ??:? at at ??:? [4] #??:? 4 ??:? [1] #4 Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::List<int> const&, Foam::List<Foam::Pair<int> > const&, Foam::HashSet<int, Foam::Hash<int> >&)[5] #4 Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::List<int> const&, Foam::List<Foam::Pair<int> > const&, Foam::HashSet<int, Foam::Hash<int> >&)Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::List<int> const&, Foam::List<Foam::Pair<int> > const&, Foam::HashSet<int, Foam::Hash<int> >&)[2] #4 [3] #4 Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::List<int> const&, Foam::List<Foam::Pair<int> > const&, Foam::HashSet<int, Foam::Hash<int> >&)Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::List<int> const&, Foam::List<Foam::Pair<int> > const&, Foam::HashSet<int, Foam::Hash<int> >&) at ??:? at [5] #5 ??:? Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::HashSet<int, Foam::Hash<int> >&)[3] #5 Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::HashSet<int, Foam::Hash<int> >&) at ??:? [4] #5 Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::HashSet<int, Foam::Hash<int> >&) at ??:? at [1] #5 at Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::HashSet<int, Foam::Hash<int> >&)??:? ??:? [2] #5 [0] #5 Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::HashSet<int, Foam::Hash<int> >&)Foam::motionSmootherAlgo::checkMesh(bool, Foam::polyMesh const&, Foam::dictionary const&, Foam::HashSet<int, Foam::Hash<int> >&) at ??:? [3] #6 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [5] #6 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [4] #6 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at ??:? [2] #6 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at at ??:? [0] #6 ??:? Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&)[1] #6 Foam::meshRefinement::mergePatchFacesUndo(double, double, Foam::List<int> const&, Foam::dictionary const&, Foam::List<int> const&) at at at ??:? at at ??:? [0] #7 ??:? ??:? ??:? Foam::snappyRefineDriver::mergePatchFaces(bool, Foam::refinementParameters const&, Foam::dictionary const&) at [1] #7 [3] #7 [2] #7 ??:? [4] #7 Foam::snappyRefineDriver::mergePatchFaces(bool, Foam::refinementParameters const&, Foam::dictionary const&)Foam::snappyRefineDriver::mergePatchFaces(bool, Foam::refinementParameters const&, Foam::dictionary const&)Foam::snappyRefineDriver::mergePatchFaces(bool, Foam::refinementParameters const&, Foam::dictionary const&)Foam::snappyRefineDriver::mergePatchFaces(bool, Foam::refinementParameters const&, Foam::dictionary const&)[5] #7 Foam::snappyRefineDriver::mergePatchFaces(bool, Foam::refinementParameters const&, Foam::dictionary const&) at ??:? [3] #8 Foam::snappyRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, bool, Foam::dictionary const&) at ??:? [5] #8 Foam::snappyRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, bool, Foam::dictionary const&) at at ??:? ??:? [2] #8 Foam::snappyRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, bool, Foam::dictionary const&) at [0] #8 at ??:? Foam::snappyRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, bool, Foam::dictionary const&)[4] #8 ??:? Foam::snappyRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, bool, Foam::dictionary const&)[1] #8 Foam::snappyRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, bool, Foam::dictionary const&) at at ??:? ??:? [5] #9 [3] #9 at ??:? [2] #9 at ??:? [4] #9 at at ??:? [1] #??:? [0] #9 9 ?????? at at ??:? ??:? [3] #10 [5] #10 __libc_start_main__libc_start_main at ??:? [2] #10 __libc_start_main at ??:? [4] #10 __libc_start_main at at ??:? ??:? [0] #10 __libc_start_main[1] #10 __libc_start_main in /usr/lib64/libc.so.6 [3] #11 in /usr/lib64/libc.so.6 [5] #11 in /usr/lib64/libc.so.6 [2] #11 in /usr/lib64/libc.so.6 [4] #11 in /usr/lib64/libc.so.6 [1] #11 in /usr/lib64/libc.so.6 [0] #11 ?????? at ??:? [node07:59591:0:59591] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2)) at ??:? [node07:59593:0:59593] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2)) at ??:? [node07:59590:0:59590] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2)) at ??:? [node07:59592:0:59592] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2)) at ??:? at ??:? [node07:59587:0:59587] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2)) [node07:59588:0:59588] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2)) ==== backtrace ==== 0 0x000000000000f59b raise() ???:0 1 0x000000000000f6d0 _L_unlock_13() funlockfile.c:0 2 0x00000000004458c0 Foam::polyMeshGeometry::checkCellDeterminant() ???:0 3 0x0000000000439e9a Foam::motionSmootherAlgo::checkMesh() ???:0 4 0x000000000043acc4 Foam::motionSmootherAlgo::checkMesh() ???:0 5 0x000000000020aeb7 Foam::meshRefinement::mergePatchFacesUndo() ???:0 6 0x0000000000197fa5 Foam::snappyRefineDriver::mergePatchFaces() ???:0 7 0x0000000000198be8 Foam::snappyRefineDriver::doRefine() ???:0 8 0x000000000041d604 main() ???:0 9 0x0000000000022445 __libc_start_main() ???:0 10 0x0000000000410634 _start() ???:0 =================== ==== backtrace ==== 0 0x000000000000f59b raise() ???:0 1 0x000000000000f6d0 _L_unlock_13() funlockfile.c:0 2 0x00000000004458c0 Foam::polyMeshGeometry::checkCellDeterminant() ???:0 3 0x0000000000439e9a Foam::motionSmootherAlgo::checkMesh() ???:0 4 0x000000000043acc4 Foam::motionSmootherAlgo::checkMesh() ???:0 5 0x000000000020aeb7 Foam::meshRefinement::mergePatchFacesUndo() ???:0 6 0x0000000000197fa5 Foam::snappyRefineDriver::mergePatchFaces() ???:0 7 0x0000000000198be8 Foam::snappyRefineDriver::doRefine() ???:0 8 0x000000000041d604 main() ???:0 9 0x0000000000022445 __libc_start_main() ???:0 10 0x0000000000410634 _start() ???:0 =================== ==== backtrace ==== 0 0x000000000000f59b raise() ???:0 1 0x000000000000f6d0 _L_unlock_13() funlockfile.c:0 2 0x00000000004458c0 Foam::polyMeshGeometry::checkCellDeterminant() ???:0 3 0x0000000000439e9a Foam::motionSmootherAlgo::checkMesh() ???:0 4 0x000000000043acc4 Foam::motionSmootherAlgo::checkMesh() ???:0 5 0x000000000020aeb7 Foam::meshRefinement::mergePatchFacesUndo() ???:0 6 0x0000000000197fa5 Foam::snappyRefineDriver::mergePatchFaces() ???:0 7 0x0000000000198be8 Foam::snappyRefineDriver::doRefine() ???:0 8 0x000000000041d604 main() ???:0 9 0x0000000000022445 __libc_start_main() ???:0 10 0x0000000000410634 _start() ???:0 =================== ==== backtrace ==== 0 0x000000000000f59b raise() ???:0 1 0x000000000000f6d0 _L_unlock_13() funlockfile.c:0 2 0x00000000004458c0 Foam::polyMeshGeometry::checkCellDeterminant() ???:0 3 0x0000000000439e9a Foam::motionSmootherAlgo::checkMesh() ???:0 4 0x000000000043acc4 Foam::motionSmootherAlgo::checkMesh() ???:0 5 0x000000000020aeb7 Foam::meshRefinement::mergePatchFacesUndo() ???:0 6 0x0000000000197fa5 Foam::snappyRefineDriver::mergePatchFaces() ???:0 7 0x0000000000198be8 Foam::snappyRefineDriver::doRefine() ???:0 8 0x000000000041d604 main() ???:0 9 0x0000000000022445 __libc_start_main() ???:0 10 0x0000000000410634 _start() ???:0 =================== ==== backtrace ==== 0 0x000000000000f59b raise() ???:0 1 0x000000000000f6d0 _L_unlock_13() funlockfile.c:0 2 0x00000000004458c0 Foam::polyMeshGeometry::checkCellDeterminant() ???:0 3 0x0000000000439e9a Foam::motionSmootherAlgo::checkMesh() ???:0 4 0x000000000043acc4 Foam::motionSmootherAlgo::checkMesh() ???:0 5 0x000000000020aeb7 Foam::meshRefinement::mergePatchFacesUndo() ???:0 6 0x0000000000197fa5 Foam::snappyRefineDriver::mergePatchFaces() ???:0 7 0x0000000000198be8 Foam::snappyRefineDriver::doRefine() ???:0 8 0x000000000041d604 main() ???:0 9 0x0000000000022445 __libc_start_main() ???:0 10 0x0000000000410634 _start() ???:0 =================== ==== backtrace ==== 0 0x000000000000f59b raise() ???:0 1 0x000000000000f6d0 _L_unlock_13() funlockfile.c:0 2 0x00000000004458c0 Foam::polyMeshGeometry::checkCellDeterminant() ???:0 3 0x0000000000439e9a Foam::motionSmootherAlgo::checkMesh() ???:0 4 0x000000000043acc4 Foam::motionSmootherAlgo::checkMesh() ???:0 5 0x000000000020aeb7 Foam::meshRefinement::mergePatchFacesUndo() ???:0 6 0x0000000000197fa5 Foam::snappyRefineDriver::mergePatchFaces() ???:0 7 0x0000000000198be8 Foam::snappyRefineDriver::doRefine() ???:0 8 0x000000000041d604 main() ???:0 9 0x0000000000022445 __libc_start_main() ???:0 10 0x0000000000410634 _start() ???:0 =================== -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 3 with PID 0 on node node07 exited on signal 8 (Floating point exception). A few additional questions: Why compiling with -fopenmp ? As much as I know, OF uses only openMPI. Did you test your compiled version on, for example, the motorBike tutorial? Thank you! |
February 25, 2019, 02:57 |
Rep Power: 7 |
1. Please install the following package dependencies :
sudo apt-get install zlib1g-dev libc6-dev-amd64 libc6-dev-i386 flex bison libomp-dev 2. The libomp-dev package will resolve the "'omp.h' file not found" issue. It has the openmp support in the OpenFOAM 1812 sources. 3. Use the environment setting $unset FOAM_SIGFPE or $export FOAM_SIGFPE=false for the floating point related issue resolution. 4. Yes, it has been tested with the motorbike example. Feel free to ask any further information. |
February 27, 2019, 04:59 |
#11 |
davide
Rep Power: 8 |
Hi
I managed to compile OF with the AMD compiler on Ubuntu 16.04 by following your guide. Thank you! On our cluster running centos 7.5 however, I had to compile twice. Basically, I followed your guide and after the first compilation I re-compiled without this step: Code:
echo "Set Compiler Settings " unset C_INCLUDE_PATH unset CPLUS_INCLUDE_PATH I tested on a couple of tutorials and everything seems fine. Thank you! |
1806, amd epyc, aocc, centos 7 |
AMD Epyc CFD benchmarks with Ansys Fluent | flotus1 | Hardware | 55 | November 12, 2018 05:33 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
OpenFOAM 13 AMD quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | November 10, 2007 23:23 |
