[OpenFOAM.org] Non-root installation of OpenFOAM 2.4.x, parallel issue |
February 28, 2019, 16:42 |
Syavash Asgari
Rep Power: 18 |
Hi Foamers,
I have been trying to install OF 2.4.x on a CentOS 7 cluster. It was fine in serial but when I try to submit a job in parallel I get the following error: Code:
Could not retrieve MPI tag from /home/.../.../.../OpenFOAM/OpenFOAM-2.4.x/platforms/linux64GccDPOpt/bin/pimpleFoam Code:
#!/bin/bash #SBATCH -N 4 #SBATCH -t 00:10:00 #SBATCH -J ... #SBATCH -A ... export FOAM_INST_DIR=/home/.../.../.../OpenFOAM . $FOAM_INST_DIR/OpenFOAM-2.4.x/etc/bashrc #--nranks is used when less than the number of available cores is used mpprun --nranks=128 `which pimpleFoam` -parallel >& results Code:
The buildenv-gcc module makes available: - Compilers: gcc, gfortran, etc. - MPI library with mpi-wrapped compilers: OpenMPI with mpicc, mpifort, etc. - Numerical libraries: OpenBLAS, LAPACK, ScaLAPACK, FFTW Regards, Syavash |
February 28, 2019, 17:20 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Given that OpenFOAM's "etc/bashrc" file is being used in the job script, then you also need to load in the job script the module for Open-MPI, before sourcing/activating OpenFOAM's shell environment.
March 1, 2019, 05:36 |
#3 | |
Syavash Asgari
Rep Power: 18 |
Thanks for your reply. I tried to include the following line in the job script: Code:
export FOAM_MPI=/software/sse/easybuild/prefix/modules/all/Compiler/GCC/6.4.0-2.28/OpenMPI Code:
. $FOAM_INST_DIR/OpenFOAM-2.4.x/etc/bashrc Regards, Syavash |
March 1, 2019, 11:57 |
Fatih Ertinaz
Rep Power: 15 |
Hello Ehsan
How exactly did you install OF, using openmpi module in the cluster or the openmpi shipped with OF? If you want to stick to the cluster's OMPI (which is the right way usually), then be sure that you made the required modifications in the OF's bashrc file. To check if everything is built correctly, you can have a look at the $FOAM_LIBBIN contents as well. Also, I'd suggest ldd tool to check if dependencies can be resolved. |
March 1, 2019, 14:44 |
#5 | |
Syavash Asgari
Rep Power: 18 |
Thanks for your attention. Honestly, I am not so sure, however I intend to use system default gcc/open-mpi modules. I followed the steps described in the following link: HTML Code:
https://openfoamwiki.net/index.php/Installation/Linux/OpenFOAM-2.4.x/CentOS_SL_RHEL#CentOS_7.1 Code:
module load buildenv-gcc/2018a-eb Code:
You have loaded an gcc buildenv module *************************************************** The buildenv-gcc module makes available: - Compilers: gcc, gfortran, etc. - MPI library with mpi-wrapped compilers: OpenMPI with mpicc, mpifort, etc. - Numerical libraries: OpenBLAS, LAPACK, ScaLAPACK, FFTW Regards, Syavash Edit: when I enter the command below Code:
cd $FOAM_LIBBIN Code:
/home/.../.../.../OpenFOAM/OpenFOAM-2.4.x/platforms/linux64GccDPOpt/lib |
March 1, 2019, 15:31 |
Fatih Ertinaz
Rep Power: 15 |
All right, I think the problem is the module you loaded doesn't actually load openmpi environment. It seems like it is a compiler module to access actual compilers (not just runtime libs) as well as to load the other modules built with that specific gcc version.
To check whether you have ompi in your environment, you can run something like: "which mpirun". Since I don't know how your cluster is configured you might want to check mpi compilers as well with "which mpicc". If you don't have those binaries located somewhere then you need to load the specific openmpi module and re-start the compilation. If you have them in your environment and also if you're sure that built was completed using correct openmpi modules, then your job script can be wrong as well. So in general: == Before initiating the installation load correct modules of gcc and openmpi. Rest is optional (boost, metis etc.). After loading them, make sure they are loaded properly. You can use commands like which, module show etc. == Check OF path is correctly defined in the etc/bashrc file (e.g. $HOME/OpenFOAM) == Make sure "export WM_MPLIB=SYSTEMOPENMPI" is defined in OF/etc/bashrc when you use the ompi module == After the installation check if mpi directories exist (e.g. openmpi-system) under the $FOAM_LIBBIN. So just being able to cd there doesn't mean much. == To run solvers, meshers etc. load the same modules required for build == Don't forget to source OF/etc/bashrc in your scripts == Don't put an alias for it since multi-node jobs need to source it by default Good luck // Fatih |
March 2, 2019, 15:43 |
#7 | |
Syavash Asgari
Rep Power: 18 |
Thanks for your elaboration. Well, I used "which mpirun" and "which mpicc" and I got the following outputs: Code:
$which mpirun /software/sse/easybuild/prefix/software/OpenMPI/1.10.3-GCC-5.4.0-2.26/bin/mpirun Code:
$which mpicc /software/sse/manual/mpprun/4.0/nsc-wrappers/mpicc Also, inside $FOAM_LIBBIN I have "openmpi-system" directory which contains the following objects: Code:
$ls libPstream.so libptscotchDecomp.so Regards, Syavash |
March 2, 2019, 16:28 |
Bruno Santos
Rep Power: 128 |
Quick answer @syavash: Why can't you add this line:
. $FOAM_INST_DIR/OpenFOAM-2.4.x/etc/bashrc The other hypothesis is to check if this module will in fact load other modules. If you start a new terminal and run: Code:
module load buildenv-gcc/2018a-eb module list |
March 3, 2019, 03:12 |
#9 | ||
Syavash Asgari
Rep Power: 18 |
Dear Bruno,
Thanks for your reply. Quote:
alias OF24x='export FOAM_INST_DIR=/home/.../.../.../OpenFOAM; module load buildenv-gcc/2018b-eb; source /home/.../.../.../OpenFOAM/OpenFOAM-2.4.x/etc/bashrc WM_NCOMPPROCS=4 WM_MPLIB=SYSTEMOPENMPI' Code:
module load buildenv-gcc/2018b-eb Code:
. $FOAM_INST_DIR/OpenFOAM-2.4.x/etc/bashrc Quote:
You have loaded an gcc buildenv module *************************************************** The buildenv-gcc module makes available: - Compilers: gcc, gfortran, etc. - MPI library with mpi-wrapped compilers: OpenMPI with mpicc, mpifort, etc. - Numerical libraries: OpenBLAS, LAPACK, ScaLAPACK, FFTW It also makes a set of dependency library modules available via the regular module command. Just do: module avail to see what is available. Code:
module list Code:
Currently Loaded Modules: 1) mpprun/4.0 2) nsc/.1.0 (H,S) 3) EasyBuild/3.5.3-nsc17d8ce4 4) nsc-eb-scripts/1.0 5) buildtool-easybuild/3.5.3-nsc17d8ce4 6) GCCcore/6.4.0 7) binutils/.2.28 (H) 8) GCC/6.4.0-2.28 9) numactl/.2.0.11 (H) 10) hwloc/.1.11.8 (H) 11) OpenMPI/.2.1.2 (H) 12) OpenBLAS/.0.2.20 (H) 13) FFTW/.3.3.7 (H) 14) ScaLAPACK/.2.0.2-OpenBLAS-0.2.20 (H) 15) foss/2018a 16) buildenv-gcc/2018a-eb Where: S: Module is Sticky, requires --force to unload or purge H: Hidden Module Regards, Syavash |
March 3, 2019, 09:14 |
#10 |
Bruno Santos
Rep Power: 128 |
Quick answer: If using "module load" doesn't work within a job, then it's because it's not able to properly load it... or because mpprun needs to be used properly.
If the cluster/supercomputer you are using has a support page, you should consult it and tell us about it if you cannot understand it! I did a quick search online for mpprun and found this page: https://www.nsc.liu.se/support/tutorials/mpprun/ Apparently the error message: Code:
Could not retrieve MPI tag from .../pimpleFoam So if you run in the login node this command: Code:
dumptag $(which pimpleFoam) Apparently you must use the "-Nmpi" additional compilation argument, as documented here: https://www.nsc.liu.se/software/buildenv/ and here: https://www.nsc.liu.se/software/mpi-libraries/ Therefore, if my estimates are correct:
March 3, 2019, 16:24 |
#11 | |
Syavash Asgari
Rep Power: 18 |
I should also thank you again as your thorough elaboration made the job run in parallel. As you instructed I did a fresh installation, this time by including -Nmpi flag. Regards, Syavash |
March 3, 2019, 18:21 |
#12 |
Bruno Santos
Rep Power: 128 |
Quick answer: I'm very glad that it worked!
Mmm... it is possible that Google was bias towards me, given my search profile, even though I wasn't logged in... Then again, when i searched for "Could not retrieve MPI tag from" without the quotes, it didn't give me anything, but with the quotes, it did give me just one answer: http://www.tfd.chalmers.se/~hani/wik.../_Installation - namely one of Håkan Nilsson's wiki pages, but I didn't understand very well the context either, since his solution was to simply use Intel MPI... I did have to research a bit more and happened to look for "mpprun" and started to read through things a bit more carefully. But I was also expecting that the cluster/supercomputer you are using, would have an instructions page... but I'm glad that NSC has a fairly complete instructions page and managed to help us out! |
March 4, 2019, 07:15 |
#13 | |
Syavash Asgari
Rep Power: 18 |
You are right about Håkan's page, as I had installed OF 2.3.1 based on his guide and had used Intel as the compiler. However, Intel compiler would give me some issues when I wanted to use mapFields or when trying to extract lines of data by sampleDict. I had previously installed OF 2.3.1 on another cluster with Gcc (though an older version) and I did not have those issues, so I decided to install OF 2.4.x with Gcc this time, hoping that it does not complain with mapFields anymore. Also, I examined NSC page. As you indicated they have provided a fairly helpful support page so I will check it out before bringing up the issue here! Regards, Syavash Last edited by syavash; March 4, 2019 at 08:42. |
[OpenFOAM.org] OpenFoam installation on CentOs 6.5 without root access | arsalan.dryi | OpenFOAM Installation | 28 | March 6, 2021 11:31 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
