Uninstall Openfoam6
Dear foamers,
How can I to remove Openfoam6 from ubuntu 18.04? Thanks a lot Kerim |
Quick answer: https://openfoamwiki.net/index.php/F...ve_OpenFOAM.3F
Uninstall Openfoam6
Dear wyldckat,
Many thanks for your help. I followed yours advice and solved my problem. I decided come back to openfoam5 becouse of next problem. I solved caseA, caseB and case C from AIJ database in OpenFOAM 5. When I use Openfoam6, I have next results: For caseA the max number of iteration is reduced from 1239 (Openfoam5) to 1218 (Openfoam6). For caseB the max number of iteration is the same: 1715 (Openfoam5) and 1715 (Openfoam6). For caseC I have floating point exception (core dumped). Could you explain me what is going on? Best regards, Kerim |
Uninstall Openfoam6
Dear wyldkat,
Finally I understand, that SetDiscreteFields was reason of my problem. AIJ caseC uses this utility I compile SetDiscreteFields and all thing is OK. Thank you for helping. Regards, Kerim |
I'm working on something related to the building's outdoor wind environment. One paper mentions that using setdiscretefields can adjust the boundary conditions to be consistent with the wind tunnel data provided by the AIJ, and this tool doesn't seem to be applicable to the new version of openfoam anymore, does it? I'm excited to find out you accomplished the same thing. I am using software based on openfoam5, I would like to ask how to verify it in the case of openfoam5? Is there a version of this tool for use with OF5? Hope to hear from you, thanks! |
