[OpenFOAM.org] OpenFOAM installation problem (of7 not working)
Like Tree1Likes
  • 1 Post By Krao
Old   September 19, 2019, 08:04
Default OpenFOAM installation problem (of7 not working)
anonymous
tenichols19 is on a distinguished road
I recently downloaded OpenFOAM on an Ubuntu 18 machine and it has been working great until I tried to run the alias "of7" which I needed for a tutorial I'm following.
After I ran "of7" I got the following message "(pathNo such file or directory"
When I downloaded I followed https://openfoam.org/download/7-ubuntu/
Any help would be greatly appreciated.
tenichols19 is offline   Reply With Quote
Old   September 19, 2019, 08:52
Kmeti Rao
Krao is on a distinguished road
Hi Tenichols,
Did you add this line 'source /opt/openfoam7/etc/bashrc' at the end of your bashrc? How you have defined your alias? If you post that, it would be easy to look into your problem.
Krao
Krao is offline   Reply With Quote
Old   September 19, 2019, 09:33
anonymous
Krao
Yes I have executed the following:
"gedit ~/.bashrc"
and added "source /opt/openfoam7/etc/bashrc" at the bottom of that file and saved.
I am curious though, when I go to my bashrc file manually "gedit /opt/openfoam7/etc/bashrc" The file looks different than when I use ""gedit ~/.bashrc", what is going on here?
What do you mean by How you defined your alias?
Sorry I'm new to all this. I appreciate your help.
Old   September 20, 2019, 02:24
Kmeti Rao
You have mentioned that you have executed of7 and it is not working. Here in your case 'of7' is the alias (short name or nick name) for 'source /opt/openfoam7/etc/bashrc'. So if you have not mentioned alias, add this following line at the end of your gedit ~/.bashrc
alias of70='source /opt/openfoam7/etc/bashrc'
If you want to know more about, how to define alias go to this following link and refer section 2.2.2https://openfoamwiki.net/index.php/I...with_the_Shell
If you have installed in a different directory then check out this link, it might help you bash: /opt/openfoam230/etc/bashrc: No such file or directory
Hope this is clear for you,
Krao
wyldckat likes this.
alias, installation, openfoam
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
OpenFOAM 2.2.2 source pack installation on Xubuntu 13.10 zordiack OpenFOAM Installation 1 October 26, 2013 13:08
compiler problem with OpenFOAM installation belkadi OpenFOAM Installation 4 May 22, 2013 10:26
Problem? with Installation of OpenFOAM 2.1.0 on to Ubuntu 10.4.4 VirtualBox Stubby OpenFOAM Installation 8 March 5, 2012 15:12
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
