[OpenFOAM.com] 'laplacianFoam' failed
Like Tree2Likes
  • 2 Post By nik86
Old   March 7, 2019, 13:20
Unhappy 'laplacianFoam' failed
Nicola
nik86 is on a distinguished road
Hi OpenFoam users,
I am a new OF user and during the installation I got these error messages and I do not know how to fix it:
wmake laplacianFoam
make[2]: ingresso nella directory "/home/nik/OpenFOAM/OpenFOAM-v1812/applications/solvers/basic/laplacianFoam"
wmake overLaplacianDyMFoam
make[3]: ingresso nella directory "/home/nik/OpenFOAM/OpenFOAM-v1812/applications/solvers/basic/laplacianFoam/overLaplacianDyMFoam"
g++ -std=c++11 -m64 -DOPENFOAM=1812 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100 -I/home/nik/OpenFOAM/OpenFOAM-v1812/src/finiteVolume/lnInclude -I/home/nik/OpenFOAM/OpenFOAM-v1812/src/dynamicFvMesh/lnInclude -I/home/nik/OpenFOAM/OpenFOAM-v1812/src/overset/lnInclude -I/home/nik/OpenFOAM/OpenFOAM-v1812/src/meshTools/lnInclude -IlnInclude -I. -I/home/nik/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude -I/home/nik/OpenFOAM/OpenFOAM-v1812/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed /home/nik/OpenFOAM/OpenFOAM-v1812/build/linux64GccDPInt32Opt/applications/solvers/basic/laplacianFoam/overLaplacianDyMFoam/overLaplacianDyMFoam.o -L/home/nik/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib \
    -loverset -lOpenFOAM -ldl  \
     -lm -o /home/nik/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/overLaplacianDyMFoam
/home/nik/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so: riferimento non definito a "MPI::Op::Init(void (*)(void const*, void*, int, MPI::Datatype const&), bool)"
/home/nik/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so: riferimento non definito a "PMPI::Intracomm::current_op"
/home/nik/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so: riferimento non definito a "PMPI::Comm::mpi_comm_map"
/home/nik/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so: riferimento non definito a "MPI::Is_initialized()"
/home/nik/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so: riferimento non definito a "PMPI::Comm::mpi_err_map"
/home/nik/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so: riferimento non definito a "MPI::Op::Free()"
/home/nik/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so: riferimento non definito a "op_intercept"
collect2: error: ld returned 1 exit status
/home/nik/OpenFOAM/OpenFOAM-v1812/wmake/makefiles/general:136: recipe for target '/home/nik/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/overLaplacianDyMFoam' failed
make[3]: *** [/home/nik/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt32Opt/bin/overLaplacianDyMFoam] Error 1
make[3]: uscita dalla directory "/home/nik/OpenFOAM/OpenFOAM-v1812/applications/solvers/basic/laplacianFoam/overLaplacianDyMFoam"
/home/nik/OpenFOAM/OpenFOAM-v1812/wmake/makefiles/apps:27: recipe for target 'overLaplacianDyMFoam' failed
make[2]: *** [overLaplacianDyMFoam] Error 2
make[2]: uscita dalla directory "/home/nik/OpenFOAM/OpenFOAM-v1812/applications/solvers/basic/laplacianFoam"
/home/nik/OpenFOAM/OpenFOAM-v1812/wmake/makefiles/apps:27: recipe for target 'laplacianFoam' failed
make[1]: *** [laplacianFoam] Error 2
make[1]: uscita dalla directory "/home/nik/OpenFOAM/OpenFOAM-v1812/applications/solvers/basic"
/home/nik/OpenFOAM/OpenFOAM-v1812/wmake/makefiles/apps:27: recipe for target 'basic' failed
make: *** [basic] Error 2
Anyone could help me in fixing the installation?
I am using Ubuntu 18.04 and OpenFoam v1812.
Thanks
Nik
Last edited by wyldckat; March 7, 2019 at 18:32. Reason: Added [CODE][/CODE] markers
nik86 is offline   Reply With Quote
Old   March 7, 2019, 18:34
Retired Super Moderator
Bruno Santos
Quick questions:
  1. Which installation instructions are you following?
  2. What do the following commands give you?
    mpirun --version
    mpicc --version
Old   March 8, 2019, 05:50
Nicola
Hi Wyldckat,
many thanks for your reply.
I was following this guide:
https://www.openfoam.com/code/build-guide.php
However, I found an old post from you which already describe how to fix my installation with the following steps:
wclean $FOAM_SOLVERS/basic/laplacianFoam
wmake all $FOAM_SOLVERS/basic/laplacianFoam > log.make.laplacian 2>&1
gzip < log.make.laplacian > log.make.laplacian.gz
cd $WM_PROJECT_DIR
ln -s /usr/bin/mpicc.openmpi bin/mpicc
ln -s /usr/bin/mpirun.openmpi bin/mpirun
wclean all src/Pstream
wmRefresh
./Allwmake -j 4 > log.make 2>&1
Many thanks again
Nik
wyldckat and randolph like this.
Old   September 9, 2019, 22:58
Zhou Zhang
josephchou is on a distinguished road
Originally Posted by nik86 View Post
Hi Wyldckat,
cd $WM_PROJECT_DIR
wmRefresh
Many thanks again
Nik
Hi Nik,
I had the same problem as yours. But after following the steps you mentioned above, it gave the same error. Do you have any idea how to fix it? And could you tell me in which 'old post' you found the solution? By the way, I was using Open MPI 3.1.4, gcc 4.8.5. Thanks a lot!
Zhou
josephchou is offline   Reply With Quote
failed, installation, laplacianfoam, mpi
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
