[foam-extend.org] Installation foam-extend-4.1 on Ubuntu 19.04
Old   May 17, 2019, 06:15
Default Installation foam-extend-4.1 on Ubuntu 19.04
Alessandro Tassone
zethani is on a distinguished road
Hello everyone,
I am trying to install both OpenFOAM and foam-extend on a virtual machine running Ubuntu 19.04 (host Windows 7, VirtualBox) following these instructions: https://pingpong.chalmers.se/public/...o?item=4764601
Everything went smoothly for OpenFOAM, but I have found a lot of issues for foam-extend, i.e. Allwmake reports several errors and cavity tutorial fails to run.
I tried to follow the instructions on the wiki (http://openfoamwiki.net/index.php/In...end-4.0/Ubuntu, for Ubuntu 18.04) but, again, Allwmake reports about 1000 errors. Moreover, the dependencies gcc-5 g++-5 are not retrieved by apt-get and, apparantely, they are deprecated.
I am wondering maybe if Ubuntu 19.04 is not yet supported by foam-extend. Did anyone try to install it?
Many thanks
Alessandro
zethani is offline   Reply With Quote
Old   June 16, 2019, 15:40
Retired Super Moderator
Bruno Santos
Quick answer: I don't know if you've solved this issue, but if not, here's a similar thread: foam-extend-4.0 Debian Testing bison problem fseterr.c - this is because Debian Testing should be similar in versions to Ubuntu 19.04.
Old   December 8, 2019, 04:44
Elyas_Kermani
Elyas_Mosibat is on a distinguished road
Originally Posted by zethani View Post
Hello everyone,
Many thanks
Alessandro
Hi Alessandro,
I have the same problem when I am trying to install Foam-extend 4.0 on ubuntu 19.10. Could you please explain how you solved the problem? thanks,
Elyas_Mosibat is offline   Reply With Quote
Old   April 26, 2020, 09:17
Default Gcc 4.3.3
Elaxender david
Engin.shlxtn is on a distinguished road
Hi
I have same problem. It required gcc-4.3.3.
Engin.shlxtn is offline   Reply With Quote
[OpenFOAM.org] Open FOAM 4.1 installation on Ubuntu 17.04 (32 bit). Openguy OpenFOAM Installation 2 September 7, 2017 10:33
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
ParaView-4.0.1 did not compile for foam extend 3.0 installation mhkenergy OpenFOAM Installation 8 June 4, 2014 02:26
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
