[OpenFOAM.org] Compilation error (openFOAM v4.1) |
June 13, 2019, 08:01 |
Praveen Srinivasa
Hej,
I am a new user of openFOAM and I am trying ton install openFOAM V4.1 (without docker) on our computational clusters. I encountered a compilation error and require some help figuring out what it is. WE are using the SLES 15 (2018) I am attaching the error message below, please take a look at it. Code:
Making dependency list for source file foamyQuadMesh.C Making dependency list for source file shortEdgeFilter2D.C Making dependency list for source file CV2DIO.C Making dependency list for source file insertBoundaryConformPointPairs.C Making dependency list for source file insertSurfaceNearPointPairs.C Making dependency list for source file insertSurfaceNearestPointPairs.C Making dependency list for source file insertFeaturePoints.C Making dependency list for source file CV2D.C g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -frounding-math -DNDEBUG -I/home/u049944/OpenFOAM/ThirdParty-4.1/platforms/linux64Gcc/cgal-system/include -I/include -I/include -I/home/u049944/OpenFOAM/ThirdParty-4.1/platforms/linux64Gcc/boost-system/include -I/usr/include -Wno-old-style-cast -Wno-unused-local-typedefs -Wno-array-bounds -I/home/u049944/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh/generation/extrude2DMesh/extrude2DMesh/lnInclude -I../conformalVoronoi2DMesh/lnInclude -I../conformalVoronoiMesh/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/parallel/decompose/decompositionMethods/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/meshTools/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/surfMesh/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/edgeMesh/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/dynamicMesh/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/mesh/extrudeModel/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/sampling/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/triSurface/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/fileFormats/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/mesh/snappyHexMesh/lnInclude -IlnInclude -I. -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude -I/home/u049944/OpenFOAM/OpenFOAM-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c CV2D.C -o /home/u049944/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/CV2D.o In file included from CV2D.C:26:0: CV2D.H:352:51: error: \u2018point\u2019 does not name a type inline const point2D& toPoint2D(const point&) const; ^~~~~ CV2D.H:354:20: error: \u2018point\u2019 does not name a type inline point toPoint3D(const point2D&) const; ^~~~~ CV2D.H:366:20: error: \u2018point\u2019 does not name a type inline point toPoint3D(const Point&) const; ^~~~~ In file included from CV2D.H:469:0, from CV2D.C:26: CV2DI.H: In member function \u2018bool Foam::CV2D::insertMirrorPoint(const point2D&, const point2D&)\u2019: CV2DI.H:85:24: error: \u2018toPoint3D\u2019 was not declared in this scope if (qSurf_.outside(toPoint3D(mirrorPoint))) ^~~~~~~~~ CV2DI.H:85:24: note: suggested alternative: \u2018toPoint2D\u2019 if (qSurf_.outside(toPoint3D(mirrorPoint))) ^~~~~~~~~ toPoint2D CV2DI.H: At global scope: CV2DI.H:124:57: error: \u2018point\u2019 does not name a type; did you mean \u2018Point\u2019? inline const Foam:oint2D& Foam::CV2D::toPoint2D(const point& p) const ^~~~~ Point CV2DI.H:141:60: error: no \u2018Foamint Foam::CV2D::toPoint3D(const point2D&) const\u2019 member function declared in class \u2018Foam::CV2D\u2019 inline Foamint Foam::CV2D::toPoint3D(const point2D& p) const ^~~~~ CV2DI.H:176:58: error: no \u2018Foamint Foam::CV2D::toPoint3D(const Point&) const\u2019 member function declared in class \u2018Foam::CV2D\u2019 inline Foamint Foam::CV2D::toPoint3D(const Point& P) const ^~~~~ CV2D.C: In constructor \u2018Foam::CV2D::CV2D(const Foam::Time&, const Foam::dictionary&)\u2019: CV2D.C:156:9: error: no matching function for call to \u2018Foam::CV2D::point(Foam::ITstream&)\u2019 ).z() ^ In file included from /usr/include/CGAL/Delaunay_triangulation_2.h:28:0, from CGALTriangulation2DKernel.H:36, from CGALTriangulation2Ddefs.H:44, from CV2D.H:122, from CV2D.C:26: /usr/include/CGAL/Triangulation_2.h:980:1: note: candidate: const Point& CGAL::Triangulation_2<Gt, Tds>:oint(CGAL::Triangulation_2<Gt, Tds>::Face_handle, int) const [with Gt = CGAL::Epick; Tds = CGAL::Triangulation_data_structure_2<CGAL::Triangulation_hierarchy_vertex_base_2<CGAL::indexedVertex<CGAL::Epick> >, CGAL::indexedFace<CGAL::Epick> >; CGAL::Triangulation_2<Gt, Tds>::Point = CGAL::Point_2<CGAL::Epick>; CGAL::Triangulation_2<Gt, Tds>::Face_handle = CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::indexedFace<CGAL::Epick, CGAL::Triangulation_face_base_2<CGAL::Epick, CGAL::Triangulation_ds_face_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_hierarchy_vertex_base_2<CGAL::indexedVertex<CGAL::Epick> >, CGAL::indexedFace<CGAL::Epick> > > > >, CGAL:efault, CGAL:efault, CGAL:efault>, false>] Triangulation_2<Gt, Tds>:: ^~~~~~~~~~~~~~~~~~~~~~~~ /usr/include/CGAL/Triangulation_2.h:980:1: note: candidate expects 2 arguments, 1 provided /usr/include/CGAL/Triangulation_2.h:991:1: note: candidate: const Point& CGAL::Triangulation_2<Gt, Tds>:oint(CGAL::Triangulation_2<Gt, Tds>::Vertex_handle) const [with Gt = CGAL::Epick; Tds = CGAL::Triangulation_data_structure_2<CGAL::Triangulation_hierarchy_vertex_base_2<CGAL::indexedVertex<CGAL::Epick> >, CGAL::indexedFace<CGAL::Epick> >; CGAL::Triangulation_2<Gt, Tds>::Point = CGAL::Point_2<CGAL::Epick>; CGAL::Triangulation_2<Gt, Tds>::Vertex_handle = CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_hierarchy_vertex_base_2<CGAL::indexedVertex<CGAL::Epick, CGAL::Triangulation_vertex_base_2<CGAL::Epick, CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_hierarchy_vertex_base_2<CGAL::indexedVertex<CGAL::Epick> >, CGAL::indexedFace<CGAL::Epick> > > > > >, CGAL:efault, CGAL:efault, CGAL:efault>, false>] Triangulation_2<Gt, Tds>:: ^~~~~~~~~~~~~~~~~~~~~~~~ /usr/include/CGAL/Triangulation_2.h:991:1: note: no known conversion for argument 1 from \u2018Foam::ITstream\u2019 to \u2018CGAL::Triangulation_2<CGAL::Epick, CGAL::Triangulation_data_structure_2<CGAL::Triangulation_hierarchy_vertex_base_2<CGAL::indexedVertex<CGAL::Epick> >, CGAL::indexedFace<CGAL::Epick> > >::Vertex_handle {aka CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_hierarchy_vertex_base_2<CGAL::indexedVertex<CGAL::Epick, CGAL::Triangulation_vertex_base_2<CGAL::Epick, CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_hierarchy_vertex_base_2<CGAL::indexedVertex<CGAL::Epick> >, CGAL::indexedFace<CGAL::Epick> > > > > >, CGAL:efault, CGAL:efault, CGAL:efault>, false>}\u2019 CV2D.C: In member function \u2018void Foam::CV2D::insertPoints(const point2DField&, Foam::scalar)\u2019: CV2D.C:194:31: error: \u2018toPoint3D\u2019 was not declared in this scope if (qSurf_.wellInside(toPoint3D(p), nearness)) ^~~~~~~~~ CV2D.C:194:31: note: suggested alternative: \u2018toPoint2D\u2019 if (qSurf_.wellInside(toPoint3D(p), nearness)) ^~~~~~~~~ toPoint2D CV2D.C: In member function \u2018void Foam::CV2D::insertGrid()\u2019: CV2D.C:263:19: error: expected \u2018;\u2019 before \u2018p\u2019 point p(x0 + i*deltax, y0 + j*deltay, 0); ^ CV2D.C:263:13: error: statement cannot resolve address of overloaded function point p(x0 + i*deltax, y0 + j*deltay, 0); ^~~~~ CV2D.C:267:17: error: \u2018p\u2019 was not declared in this scope p.x() += pert*(rndGen.scalar01() - 0.5); ^ CV2D.C:271:35: error: \u2018p\u2019 was not declared in this scope if (qSurf_.wellInside(p, 0.5*meshControls().minCellSize2())) ^ CV2D.C: In member function \u2018void Foam::CV2D::newPoints()\u2019: CV2D.C:465:17: error: \u2018toPoint3D\u2019 was not declared in this scope toPoint3D(vert), ^~~~~~~~~ CV2D.C:465:17: note: suggested alternative: \u2018toPoint2D\u2019 toPoint3D(vert), ^~~~~~~~~ toPoint2D CV2D.C:480:61: error: no matching function for call to \u2018Foam::CV2D::toPoint2D(Foam::Vector<double>&)\u2019 alignments[vit->index()] = toPoint2D(norm[0]); ^ In file included from CV2D.H:469:0, from CV2D.C:26: CV2DI.H:124:29: note: candidate: const point2D& Foam::CV2D::toPoint2D(const int&) const inline const Foam::point2D& Foam::CV2D::toPoint2D(const point& p) const ^~~~ CV2DI.H:124:29: note: no known conversion for argument 1 from \u2018Foam::Vector<double>\u2019 to \u2018const int&\u2019 CV2DI.H:130:33: note: candidate: const point2DField Foam::CV2D::toPoint2D(const pointField&) const inline const Foam::point2DField Foam::CV2D::toPoint2D(const pointField& p) const ^~~~ CV2DI.H:130:33: note: no known conversion for argument 1 from \u2018Foam::Vector<double>\u2019 to \u2018const pointField& {aka const Foam::Field<Foam::Vector<double> >&}\u2019 CV2DI.H:149:37: note: candidate: const point2D& Foam::CV2D::toPoint2D(const Point&) const inline Foam::CV2D::point2DFromPoint Foam::CV2D::toPoint2D(const Point& P) const ^~~~ CV2DI.H:149:37: note: no known conversion for argument 1 from \u2018Foam::Vector<double>\u2019 to \u2018const Point& {aka const CGAL::Point_2<CGAL::Epick>&}\u2019 make[2]: *** [/home/u049944/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8: /home/u049944/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/CV2D.o] Error 1 make[2]: Leaving directory '/home/u049944/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh' make[1]: *** [/home/u049944/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39: generation] Error 2 make[1]: Leaving directory '/home/u049944/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh' make: *** [/home/u049944/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39: mesh] Error 2 Last edited by wyldckat; June 16, 2019 at 15:06. Reason: Added [CODE][/CODE] markers |
June 16, 2019, 15:13 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: "foamy*Mesh" applications are rarely used, so the quickest solution is to skip it. You can skip over it by running Allwmake with the option "-k", e.g.:
./Allwmake -k
September 30, 2019, 18:40 |
João Antônio Cardoso
Hi, same error here compiling OpenFOAM-4.1 (release from github), using:
cgal 4.14-1 parmetis 4.0.3.p4-1 scotch 6.0.6-1 bzip2 1.0.8-2 boost 1.69.0-2 flex 2.6.4-2 paraview 5.6.0-5 gcc 9.1.0-2 As sugested, I tried to compile using '-k' (without cleaning the build) but it produce the same error. Did I have to start compilation from beginning again? ---edit: Well, I was able to solve this compilation issue using the last released piece of code for CV2D.H (from OpenFoam-7). I tried to understand what changed using a diff but I didn't notice anything big. In a simple command: Code:
wget https://raw.githubusercontent.com/OpenFOAM/OpenFOAM-7/109ba3c8d53a8fa1e97854b168a16970aaeea951/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/CV2D.H -P $HOME/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh Last edited by joaoantoniocardoso; September 30, 2019 at 19:14. Reason: added my solution |
[foam-extend.org] foam-extend-3.2 compilation on windows | kirmaks | OpenFOAM Installation | 7 | December 3, 2019 20:20 |
[OpenFOAM.org] Compilation Error with OpenFOAM-5.x using Intel Compilers | aow | OpenFOAM Installation | 4 | April 25, 2019 16:17 |
Compilation error for OpenFOAM-ext on Ubantu 10.04 32 bit | Sargam05 | OpenFOAM Installation | 13 | March 22, 2014 05:21 |
Compilation Error (V 1.7.1; Icc 12.1.0, OpenMPI 1.4.3) | floydfan | OpenFOAM Installation | 7 | December 20, 2011 05:56 |
Compilation Error.... | Arnab | Siemens | 4 | September 12, 2004 15:54 |
