June 6, 2019, 09:39 |
OpenFOAM-5.x installation
SOURAV GANGULI
Rep Power: 7 |
I am trying to install openfoam-5.x in server. It is installed successfully. But my doubt is is there a way toavoid the command "of5x" everytime when am I trying to run the application? At least please ensure me whether is it possible or not. |
June 7, 2019, 17:25 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: The alias "of5x" is just to make it easier to be able to use other versions/variants/forks of OpenFOAM.
If you only want to always use a specific version, then you can edit the file "~/.bashrc" and remove the alias definition and replace with what it has within the quotes. For example, change this: Code:
alias of5x='source $HOME/OpenFOAM/OpenFOAM-5.x/etc/bashrc WM_MPLIB=OPENMPI FOAMY_HEX_MESH=yes' Code:
source $HOME/OpenFOAM/OpenFOAM-5.x/etc/bashrc WM_MPLIB=OPENMPI FOAMY_HEX_MESH=yes Long answer: It's explained here: https://openfoamwiki.net/index.php/I...nFOAM_versions
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
[OpenFOAM.org] Installation notes: OpenFOAM 2.3.x (git repo) on OSX 10.9 | opedrofunk | OpenFOAM Installation | 7 | July 1, 2015 13:51 |
[Discussion] Restructuring the Installation page at openfoamwiki.net | wyldckat | OpenFOAM Installation | 16 | November 2, 2013 11:43 |
Trouble shooting about OpenFOAM installation in Ubuntu 12.04 | Nait | OpenFOAM Installation | 2 | December 12, 2012 10:20 |
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 | superfxfund | OpenFOAM Installation | 3 | November 11, 2010 02:15 |
