[OpenFOAM.org] Update OpenFoam on macOS using Docker |
June 25, 2019, 11:28 |
Babak
How can I update the OpenFoam installed on Docker in MacOS? the Code:
apt-get update |
July 9, 2019, 19:08 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: In Ubuntu and Debian, to upgrade installed Deb packages via APT, you need to do 2 commands:
apt-get update apt-get upgrade
July 10, 2019, 20:26 |
Babak
At the first place, using "apt-get" does not work due to permission error on a docker image, and "sudo" is also not included by default in docker images.
I found a solution as follows: First, It requires to load the docker image via the "root" user. Such that: Code:
docker run -u 0 -it <image_name_or_id> /bin/bash Code:
docker image ls Code:
apt-get update apt-get upgrade Code:
apt-get --only-upgrade install openfoam6 Hope this would be helpful. The following link is useful: https://blog.koley.in/2018/root-user...cker-container |
docker, mac os, mac os x, openfoam 6 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
OpenFoam in docker (gcc 6) vs. OpenFoam natively compiled (gcc 8.1.1) | Anouk | OpenFOAM Running, Solving & CFD | 0 | September 17, 2018 08:02 |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 5, 2018 23:48 |
[Other] Installation of OpenFOAM: Docker or not Docker? | zt49 | OpenFOAM Installation | 2 | December 22, 2016 10:38 |
apt-get update Duplicate lists of OpenFOAM | Xulia | OpenFOAM Installation | 2 | June 20, 2013 10:13 |
