[OpenFOAM.com] OpenFOAM v1606+ could not read ca certificate
Old   July 14, 2019, 05:50
Question OpenFOAM v1606+ could not read ca certificate
Akvarel
Akvarel2505 is on a distinguished road
Hello everyone,
I need a piece of advice with the installation of OF 1606+ on Windows 7.
The installer was taken from here https://sourceforge.net/projects/ope...iles/v1606%2B/
File OpenCFD-OpenFOAM4WindowsInstaller_v1606+.exe
During the installation of OpenFoam Oracle VirtualBox, Git and Docker were installed as well.
When I tried to create OpenFoam environment I got this message. Seems to be OK, but I may be wrong... Is there any trouble here? https://yadi.sk/i/rJrM6HjZ_tK2Ng
When I start OpenFoam itself, the window shows up for a while then disappears. The error is "Could not read CA certificate". The messages are here: https://yadi.sk/i/9PW8o6Yj2Kv9_g
The certificates are exactly in that place but for some reason OpenFoam is unable to find them. How can I fix this problem? Docker itself works properly.
I have already tried to change the Environment variable "DOCKER_CERT_PATH" - I put there the right path manually but there was no effect on OpenFOAM. Also I tried to delete all docker variables (advice from Google), but there was no effect on openFoam as well...
I would appreciate any help.
Akvarel2505 is offline   Reply With Quote
Old   July 25, 2019, 19:04
Retired Super Moderator
Bruno Santos
Quick answer: Any chance you can install a more recent version of OpenFOAM.com with Docker?
Either that, or you need to uninstall Docker and install a more recent version of Docker, then use the container provided in that OpenFOAM+ installer.
Old   July 26, 2019, 01:13
Akvarel
Thanks for answer! The trick is that I need particularly this version. I already have 1806+, it works perfectly, but I need to test a code for 1606+.
Old   July 27, 2019, 09:49
Bruno Santos
Quick answer: I vaguely remember that there were some instructions somewhere on how to use the container manually that is provided in the installer... I can't find it...
OK, I haven't tested this myself, but you could try using the Docker installation that you're using from v1806+ and install the container for v1606+ manually onto Docker:
docker pull openfoamplus/of_v1606plus_centos66
Then use the scripts "startOpenFoam+" and "installOpenFOAM+" at https://sourceforge.net/projects/ope...iles/v1606%2B/ - and use them as guidance on how to start the respective containers. You might have to correlate them to how things are being done on Windows in the scripts used by v1806+.
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 05:40
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
