[Other] ParaView 5.4 freezing after start on ubuntu 18
Old   July 23, 2019, 15:07
Default ParaView 5.4 freezing after start on ubuntu 18
Jan
Jan Smedseng is on a distinguished road
last week I installed ubuntu 18 from scratch and build openfoam. Openfoam is working nice but running paraview with paraview --mesa & starts the application, which is freezing soon. If I run without --mesa, its the same. Looks like that:
https://drive.google.com/open?id=1Mb...f0k9OXOQuTGqhy
Does anybody has an idea? I also installed paraview once standalone and was able to run it correctly. But now paraView (with a capital V) is not found anymore (why ever).
Thank you for your help and regards,
Jan
Jan Smedseng is offline   Reply With Quote
Old   July 23, 2019, 19:22
Retired Super Moderator
Bruno Santos
Quick answer and a few questions:
  1. paraFoam has the upper case 'F', but 'paraView' was never a standard command, only paraview. So my guess is that either you're mixing the two or you had an alias or script with the upper case 'V'?
  2. Which specific OpenFOAM version did you build?
  3. Which installation instructions did you follow for compiling/installing OpenFOAM and ParaView?
  4. Are you referring to Ubuntu 18.04 or 18.10?
  5. Which installation instructions did you follow to build the Mesa libraries in order to use paraview --mesa?
mesa, openfoam, paraview
[OpenFOAM] ParaView 5.4.0 refuses to start SamuelPei ParaView 1 October 15, 2019 04:12
[OpenFOAM.org] Using OpenFOAM 2.3.0 from Deb pack in Ubuntu 14.04 + ParaView 5 from OpenFOAM 4.1 ad2eb OpenFOAM Installation 12 May 28, 2017 15:30
[OpenFOAM] Problem running Paraview on Ubuntu 14.04 aminthefresh ParaView 0 November 4, 2014 13:34
[OpenFOAM] Paraview on Ubuntu Tobi ParaView 1 September 27, 2013 20:03
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 wyldckat OpenFOAM Installation 14 February 12, 2013 05:43
