Uninstall Foam Extend 4.0
How do I uninstall foam-extend-4.0?
I am using ubuntu 18.04 in VirtualBox |
Quick answer: Read/follow this FAQ entry "How to uninstall/remove OpenFOAM?": https://openfoamwiki.net/index.php/F...ve_OpenFOAM.3F
How should I unistall openfoam-extend-3.2
I wanted to install foam-extend-3.2 on windows using WSL, however I did it the wrong way and located it in a wrong folder when downloading from git.
git clone git://git.code.sf.net/p/foam-extend/foam-extend-3.2 foam-extend-3.2 Even when I did not compile anything, tried to move the foam-extend folder to opt (where I understood it should be) but i get the warning Code:
mv: cannot move 'foam-extend-3.2' to '../../../opt/foam-extend-3.2': Permission denied If I ignore the downloades file, and try to downlaod again inside the right folder, I get Code:
fatal: could not create work tree dir 'foam-extend-3.2': Permission denied I know Installation Process uses MSYS, but I first to remove the folder /reinstall from my computer. ¿How I could uninstall/reinstall openfoam-extend in WSL? Thanks in advance |
