[OpenFOAM.com] Installation problem with OpenFOAM-v1906
Like Tree2Likes
  • 2 Post By dscian
Old   August 1, 2019, 13:33
Default Installation problem with OpenFOAM-v1906
Ziqu Cao
Kevin Cao is on a distinguished road
Hi, I'm a beginner of OpenFOAM and I got a problem with the installation of OpenFOAM-v1906
The operation system I uses is WINDOWS10
The problem is
I typed
gedit ~/.bashrc
and add
“source OpenFOAM/OpenFOAM-v1906/etc/bashrc” into the last line as said in the tutorial.
Then I shut down Ubuntu and restart it. It shows that:
-bash:OpenFOAM/OpenFOAM=v1906/etc /bashrc:no such file or directory
SO I wonder how to deal with such thing. Thanks
Kevin Cao is offline   Reply With Quote
Old   August 1, 2019, 22:55
Default Double Check Typing?
Peter Brady
pbrady2013 is on a distinguished road
Have you cut and pasted in the lines below?
<snip>
It looks like on one line there is a "-" and on the later a "=" as well as a " " (space).
Could that be the problem?
-pete
pbrady2013 is offline   Reply With Quote
Old   August 2, 2019, 04:29
Ziqu Cao
sorry, I just typed it and made some mistake.
the code I added in .bashrc is :
the Ubuntu gave a response as
-bash: OpenFOAM/OpenFOAM-v1906/etc/bashrc: No such file or directory
Do you know why such thing occur?
Old   August 2, 2019, 17:40
Utkan Caliskan
dscian is on a distinguished road
The path is wrong. It should be;
source $HOME/OpenFOAM/OpenFOAM-v1906/etc/bashrc
gcengineer and pbrady2013 like this.
dscian is offline   Reply With Quote
Old   August 2, 2019, 21:06
Default Correct Path
Peter Brady
dscian beat me to the punch: yes rour path is incorrect and you need to specify the full path.
Old   August 21, 2019, 09:01
Ziqu Cao
Thank you very much
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 0 January 1, 2014 19:21
problem with parmetis-3.1.1 installation for openfoam 1.6-ext achyutan OpenFOAM Installation 11 October 26, 2012 18:18
Openfoam installation problem jose soto OpenFOAM Installation 4 August 9, 2011 01:29
OpenFOAM 1.7.0 installation problem stevek OpenFOAM 14 December 1, 2010 15:30
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 01:40
