[OpenFOAM.com] question of cmake on ubuntu(OF-prerequisite)
Old   August 28, 2019, 10:57
Default question of cmake on ubuntu(OF-prerequisite)
philip lu
philiplu is on a distinguished road
i'm installing cmake on ubuntu (as OF-prerequisite), anyhow after
"./bootstrap"
following error came out
Error when bootstrapping CMake:
Cannot find appropriate Makefile processor on this system.
Please specify one using environment variable MAKE.
btw. as "...sudo apt-get install..." didn't work out with me, so I try the offline-wise, viz. use the "cmake-3.12.0.tar.gz" to install
thank you in advance if you know the reason
Philip
philiplu is offline   Reply With Quote
Old   August 28, 2019, 18:34
Bruno Santos
Quick questions:
  1. Which installation instructions are you following and which version are you trying to install?
  2. If you are following these instructions: https://www.openfoam.com/documentati...quirements.php - you need to run the following command before sudo apt-get install ...
    sudo apt-get update
    so that Ubuntu updates the package list.
Old   August 28, 2019, 21:25
Default thank you, Wyldckat
philip lu
Hello, Wyldckat,
thank you and wish you a nice day
1. you're right, I try now the "Installation From Source" in the "OF of '.com'(not '.org')" as in:
openfoam.com/download/install-source.php
openfoam.com/documentation/system-requirements.php
2. actually I did, i.e.
".....sudo apt-get update....."
".....sudo apt-get install......"
but didn't work out, so I go the "way of local viz. offline" install.........
"Readme" in "cmake-3.12.0.tar.gz" states:
________________________
you can build directly in the source tree::
$ ./bootstrap && make && sudo make install
namely no need to configure the envi variable...
so do you or does someone know what, where is wrong?
thanks in advance
Philip
(here again msg. after "./bootstrap" in Linux-Ubuntu during cmake-installation after unpacking)
Question about symmetry in Autodesk Cfd 2016 ecto Autodesk Simulation CFD 0 October 20, 2015 04:16
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
