Doxygen Documentation
When I want to use and compile doxygen doc.,after typing in the terminal :"./Allwmake doc" I encountered with this error:
/////////////////////////////////////////// ****terminal: chmod: changing permissions of '/opt/openfoam5': Operation not permitted chmod: changing permissions of '/opt/openfoam5/doc': Operation not permitted chmod: changing permissions of 'Doxygen': Operation not permitted error: Failed to open temporary file /opt/openfoam5/doc/Doxygen/doxygen_objdb_18333.tmp Exiting... Done doxygen note : I've installed doxygen and graphviz formerly. |
It seems you need to run your command with sudo to install in the /opt folder... You could, if you don't want to sudo, build the doxygen documents without going to /opt
Do you mean to execute "./Allwmake" with sudo ?! |
