[OpenFOAM.com] question of "OpenCFD-OpenFOAM-v1906-DP-mingw-crosscompiled-WindowsInstaller.exe" |
October 24, 2019, 20:49 |
philip lu
Rep Power: 6 |
the OF-linux version works fine with me, the OF-win-version of "OpenCFD-OpenFOAM-v1906-DP-mingw-crosscompiled-WindowsInstaller.exe" in win7: works also fine, but in win10: after installation, e.g. a cmd "blockMesh -help" got the error-msg as: ------------------------------------------------------------------------------ "......../ESI-OpenCFD/OpenFOAM/v1906/msys64/home/ofuser/OpenFOAM/OpenFOAM-v1906/platforms/linux64MingwDPInt32Opt/bin/blockMesh.exe error while loading shared libraries: libstdc++-6.dll: cannot open shared object file: No such file or directory" does someone know what, where is the problem? thank you |
November 29, 2019, 16:48 |
Caleb Olesen
When you run the installer you need to right click the installer and select "run as administrator". This allows MSMPI 10.0 to be installed at the same time.
December 1, 2019, 01:31 |
thx
philip lu
Rep Power: 6 |
hello, CalebO,
thank you for the reply. Probably you're right, because: after adding the missing " libstdc++-6.dll", there was still outcoming msg. of missing other stuffs. wish you a nice weekend |
December 4, 2019, 16:56 |
Herpes Free Engineer
Rep Power: 12 |
Could you please tell us if the above suggestion helped you? Might others need this in the future. Thanks.
PS: I don't give a f.ck Windows. I don't even know how to shut it down. Just saying for others
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
December 4, 2019, 22:55 |
thank u, CalebO
philip lu
Rep Power: 6 |
hi, CalebO,
thx for the reply, it works now. thank you and hope to see you again hi, HPE, it takes time but normally, it's sure u'll c my reply |
December 7, 2021, 01:42 |
#6 | |
Foad
Rep Power: 8 |
P.S. A follow-up on this discussion here on StackOverflow and here on MSYS2 Discord server.. Last edited by foadsf; December 8, 2021 at 08:06. |
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 14, 2016 10:19 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
OpenFOAM basic Question | a_yoshi | OpenFOAM | 1 | October 29, 2009 04:13 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
