OpenFOAM - 2.2.0 installation on Ubuntu 16.04
Dear All,
I followed the instructions to install OpenFOAM-2.2.0 as given below in link for Ubuntu 13.10. https://openfoamwiki.net/index.php/I...M-2.2.0/Ubuntu But, it resulted in error. Can someone suggest me how to install OpenFOAM-2.2.0 on Ubuntu 16.04? |
What is the error?
Error Message while installing
1 Attachment(s)
Thank you for replying.
My apologies. But it is ubuntu 18.04 and not 16.04. I have attached the log.make file along with this post. The error started way before, but the error message seen at the end is like this: Code:
collect2: error: ld returned 1 exit status |
Hi Sabrina,
the actual error is above the snippet you posted. I assume it is missing a library and that is causing the compilation of the application twoPhaseEulerFlow to fail. Very often that library is mpi, so check if there is a "mpi.h missing" somewhere in the path. I usually use foam-extend, but from memory, openfoam will need ThirdParty to be compiled before the actual openfoam compilation (as that will provide the included mpi libs). Another problem with compiling such an old version (2.2) on a relatively modern system (18.04) is that the compiler won't be compatible: I assume openfoam will need gcc 4, while ubuntu 18.04 has gcc 7 as default. If you check https://openfoamwiki.net/index.php/I...ibility_Matrix you will see that 2.2.0 will work with 4.7. Unfortunately the oldest gcc that U18.04 supports is 4.8. But you can try working with that. Or hunt down an old version of Ubuntu. If all fails, OF does come with a gcc provided, which you can try to compile with the more modern one, so e.g. 4.7 compiled with 4.8. If you need this to keep working, it may be worth porting the whole solver to OpenFoam-7. Could you try 2.2.2? That one has been tested with gcc 4.8. |
https://openfoamwiki.net/index.php/I...M-2.2.2/Ubuntu Still I got the same error as explained for OpenFOAM 2.2.0. My institution has latest hardware and multiple users. The admin has refused to reduce the ubuntu version to any lower one. The GCC version in the system is 7.4.0. I have been left with no choice. Since, I am not good with fixing bugs, it would be of great help, if you can show me a way how to compile the OpenFOAM-2.2.0 with the older version GCC 4.7.x. |
If you do not have root access to your system, you will need to get your sysadmin to install gcc-4.8 for you. This should not be a big deal, as it is available in the Ubuntu packaging system, so a simple apt-get install gcc-4.8 g++-4.8 should do it. Then you can try Bruno's instructions again. If 2.2.0 doesn't like 4.8, then you'll have to ask sysadmin to provide you with 4.7, which they'd need to compile themselves: https://openfoamwiki.net/index.php/I...alling_GNU_Gcc But at the moment, this is all gueswork, since you have not provided the actual error message you get. Can you post a link to the whole log file after running the compilation like: ./Allwmake | tee log.Allwmake You can also try and compile gcc-4.7 as a user, installing it in your user home directory and then adjust paths. But this can get tricky quite quickly. You'll have to learn a lot about Linux or find your local Linux wizard for that. |
EDIT: if you share your solver, I can try to compile it for you in OF1906 which works smoothly on new operating systems.
phaseChangeHeatFoam
https://github.com/NimaSam/phaseChangeHeatFoam |
after the weekend, I'm dead now. :)
Will let you know. |
This weekend, I will try to compile it for you. Bear with me. My apologies for the delay.
The wait will be worth it, if it gets compiled.
Did you get any success compiling the solver for any latest version of OpenFOAM? |
