[OpenFOAM.org] Openfoam 6 on Centos 7.7 - makeParaview error. |
January 21, 2020, 06:54 |
ssa
Rep Power: 7 |
I followed the instructions on https://openfoamwiki.net/index.php/Installation/Linux/OpenFOAM-6/CentOS_SL_RHEL#CentOS_7.5_.281804.29 when running the below command, I got error. Code:
./makeParaView -mpi -python -qmake $(which qmake-qt4) > log.makePV 2>&1 errors: Code:
collect2: error: ld returned 1 exit status make[2]: *** [lib/site-packages/mpi4py/MPI.so] Error 1 make[1]: *** [VTK/ThirdParty/mpi4py/vtkmpi4py/CMakeFiles/mpi4py.MPI.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... |
January 26, 2020, 14:56 |
Damian Berghof
Rep Power: 10 |
I did the same few weeks ago and had some trouble with the right qt configuration, if I remember correctly, since my experimental machine has crashed yesterday I configured the most libs in a conda python environment and run the building process inside of it. Can you post the entire log file? best, Damian
Get more support about Meshing with Salome and Visualization with ParaView in my growing groups https://bit.ly/2lFfDkQ https://bit.ly/2k2u8Pj |
January 27, 2020, 11:03 |
ssa
Rep Power: 7 |
I attach you the log file.
I think the problem is not with Qt. I read in the below thread that I should patch the paraview. But those commands are not working with this paraview version 5.4. https://www.cfd-online.com/Forums/paraview/129356-building-paraview-4-1-0-mpi-python-support.html#post480315 . |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
