Fluid Structure Interaction Toolkit on foam extend 4.0
Hey,
I am following this page for the installation (running ubuntu 16.04): https://openfoamwiki.net/index.php/E...oam-extend_4.0 I wanted to test the beamInCrossFlow tutorial. Everything works smoothly as far as I can tell until Allwmake tries "wmake libso setInletVelocity". Here I get the error message Code:
SOURCE=setInletVelocity.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I../../../../src/fluidSolidInteraction/lnInclude -I/opt/foam/foam-extend-4.0/src/finiteVolume/lnInclude -I/opt/foam/foam-extend-4.0/src/finiteArea/lnInclude -I/opt/foam/foam-extend-4.0/src/meshTools/lnInclude -I/opt/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude -I/opt/foam/foam-extend-4.0/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/opt/foam/foam-extend-4.0/src/foam/lnInclude -I/opt/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/setInletVelocity.o Code:
(...) Not quite sure how I have to deal with the challenge of loading the library correctly. |
The smae problem with you
I am facing the same problem with you now, when trying to use the fisFoam solver on HPC where I have no root permission. I guess this problem is probably caused due to the libsetInletVelocity.so is compiled into the root directory. Have you solved the problem or do you have idea about this problem? Best wishes |
