[OpenFOAM.com] v1906 for Windows 10- how to modify the source code
Like Tree1Likes
  • 1 Post By gian93
Old   January 3, 2020, 11:04
Default v1906 for Windows 10- how to modify the source code
giovanni
gian93 is on a distinguished road
I just downloaded OpenFoam v1906 for Windows 10. I've installed it successfully on my WLS. I can run tutorials and other simple cases. What I would really like to do is to be able to modify the source code, add boundary condition and so on. Is this possible using WSL and of OpenFoam v1906 for Windows 10 ? The first problem that I've encountered is that rootfs foleder , where is built OpenFOAM, is not accessible via WSL (permission denied).
Please give me an help to manage to access and modify the source code.
thanks in advance
gian93 is offline   Reply With Quote
Old   January 3, 2020, 22:57
tonnykz is on a distinguished road
Hi, Giovanni,
I don't really know the answer to your question. But I also once installed OpenFOAM on Windows 10 through WSL, but dealing with text files was not straightforward, so I switched to Ubuntu 18.04. Anything is much more convenient in it.
Best regards,
Tonnykz
tonnykz is offline   Reply With Quote
Old   January 4, 2020, 09:07
giovanni
I cannot change OS and install openFoam natively on ubuntu. The only thing i can do is install it through WSL. Anyone can help?
Old   January 5, 2020, 19:36
Giovanni,
I would suggest to learn how to install dualboot Ubuntu alongside yours already installed windows.
Apart from that you will have to learn a lot yourself (user guides, tutorials, internet, etc.).
Good luck,
Best regards,
Tonnykz
Old   January 30, 2020, 03:59
giovanni
problem solved: simply follow the instruction for of7 (ubuntu 1804) on openFoam wiki page.Standard source code works also on windows WSL.
I hope it will help for someone.
HPE likes this.
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
[snappyHexMesh] Invalid Normals for source face to target face while making AMI? Sorabh OpenFOAM Meshing & Mesh Conversion 1 August 3, 2021 06:35
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
