[OpenFOAM.com] Docker results different from OpenFoam native
Old   January 1, 2021, 19:59
Default Docker results different from OpenFoam native
Ivan
Ivangzp is on a distinguished road
I'm trying to validate a well-known case, turbulent flow over NACA0012. Information of the validation ca be found here: https://turbmodels.larc.nasa.gov/naca0012_val.html
I simulated properly the case with the version of OpenFoam v2006, obtaining succefull results. I can say that I validated the case because I got accuracy values for Cl and Cd for differents angles of attacks (0º, 3º, 6º, 9º, 12º and 15º). I did that with two different turbulence models (RAS-Spalart Allmaras and RAS-KwSST) using the solver simpleFoam.
The problem is the following one. I tried to run the SAME case with a version of OpenFoam installed by means of Docker. (IN THE SAME LAPTOP).
Both are supposed to be the same version but the results are differents (Relative error 30 %) and it isn't related with the time of convergence.
Has anyone suspect where can be the problem?
If someone is interested in look over the code, the case for AoA 3 degrees is here:
https://drive.google.com/file/d/1p2P...ew?usp=sharing
The case is ready to run with simpleFoam.
Thank for your time.
Ivangzp is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
k and omega at inlet for k-omega SST driu OpenFOAM Running, Solving & CFD 10 March 5, 2021 10:48
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
