[Other] Installing OpenFOAM 7 & 1912 & ExtendedFOAM
Old   April 27, 2020, 20:15
Lightbulb Installing OpenFOAM 7 & 1912 & ExtendedFOAM
Sultan Islam
EternalSeekerX is on a distinguished road
Hello everyone!
I hope everyone is staying safe during this time.
I am a CFD beginner and my only proper CFD experience was using Ansys 15 CFX and Fluent simulating 1000+ iterations of turbulent flare plate using K-epsilon, K-omega and SST solvers to validate a NASA case. I wanted to go more deeper into CFD and I have found out there are many interesting and exclusive tutorials, example cases and validation cases for many opensource and closed source programs.
I know Ansys Fluent and Star-CCM are free for students and will work on windows, as well there is only one version of Su2 code. However I found out there are 3 different variation of OpenFOAM.
I have read this old thread: OpenFOAM.com versus OpenFOAM.org: Which version to use?
I want to install and then test and run tutorials for each variations.
I have access to Ubuntu 20.10 through WSL and I also have access to Pop!OS and Manjaro in a VM for x86. Interestingly I want to also attempt to run it on an arm64/aarch64 version of Ubuntu 19.10 inside a proot container.
I understand that I can use alias in the .bashrc file to differentiate each versions.
Now I have a few questions:
1). The build instructions for each version shouldn't differ if I am running in WSL or VM correct?
2). I have read this website: https://gitlab.com/arm-hpc/packages/...kages/openfoam and It seems specifically for arm64 I can only install OF5 or OF1912. However is it possible I can build all three versions (are the files architecture agnostic) or is there a specific flag I need? Has anyone build OF for arm64?
3). Fortunately the OS I use have the latest or 2nd latest version of Paraview, can I use it or would i need to build paraview again? If i could use it, do I just skip the paraview portion of the build guide?
Anyway thanks for your patience, looking forward to hearing back.
EternalSeekerX is offline   Reply With Quote
Old   April 28, 2020, 11:31
HPE
Herpes Free Engineer
HPE is on a distinguished road
each version has a quite clear guide for installation, and they may differ, though slightly.
please follow the links below - and install them separately by referring each guide.
wish you the best.
HPE is offline   Reply With Quote
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 3 July 1, 2020 09:58
[waves2Foam] installing waves2foam into OpenFoam 6 madgeogr OpenFOAM Community Contributions 0 April 1, 2020 09:54
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
[waves2Foam] A few notes about problems and solutions when installing with OpenFOAM v1712 oceanFoam OpenFOAM Community Contributions 0 June 22, 2018 08:52
[OpenFOAM.org] Installing OpenFoam 3.0.1 on cluster hello177 OpenFOAM Installation 1 April 24, 2016 08:35
