[OpenFOAM.com] Building OpenFOAM V1912 on armh8/arm64 |
May 1, 2020, 02:48 |
Sultan Islam
Rep Power: 10 |
Dear FOAMERS,
I am attemping to build up openfoam v1912 and I ran into a hitch. I was following this website: https://gitlab.com/arm-hpc/packages/...rsion-1912-arm I wget both the openfoam and thirparty archives and then extracted it into my /opt/OpenFOAM directory. I then edited bashrc to point to this directory. When I source the bashrc I get this error: Code:
root@localhost:/opt/OpenFoam/OpenFOAM-v1912# source etc/bashrc [localhost:08533] opal_ifinit: ioctl(SIOCGIFHWADDR) failed with errno=13 No completion added for /opt/OpenFoam/OpenFOAM-v1912/platforms/linuxARM64ArmDPInt64Opt/bin ... incorrect platform, or not yet compiled? root@localhost:/opt/OpenFoam/OpenFOAM-v1912#] Code:
#------------------------------------------------------------------------------ # Configuration environment variables. # Override with <prefs.sh> instead of editing here. # [WM_COMPILER_TYPE] - Compiler location: # = system | ThirdParty export WM_COMPILER_TYPE=system # [WM_COMPILER] - Compiler: # = Gcc | Gcc4[8-9] | Gcc5[1-5] | Gcc6[1-5] | Gcc7[1-4] | Gcc8[12] | # Clang | Clang3[7-9] | Clang[4-6]0 | Icc | Cray | Arm | Pgi export WM_COMPILER=Arm # [WM_PRECISION_OPTION] - Floating-point precision: # = DP | SP | SPDP export WM_PRECISION_OPTION=DP # [WM_LABEL_SIZE] - Label size in bits: # = 32 | 64 export WM_LABEL_SIZE=64 # [WM_COMPILE_OPTION] - Optimised(default), debug, profiling, other: # = Opt | Debug | Prof # Other is processor or packaging specific (eg, OptKNL) export WM_COMPILE_OPTION=Opt # [WM_MPLIB] - MPI implementation: # = SYSTEMOPENMPI | OPENMPI | SYSTEMMPI | MPI | MPICH | MPICH-GM | # HPMPI | CRAY-MPICH | FJMPI | QSMPI | SGIMPI | INTELMPI | USERMPI # Also possible to use INTELMPI-xyz etc and define your own wmake rule export WM_MPLIB=SYSTEMOPENMPI #------------------------------------------------------------------------------ # (advanced / legacy) # [WM_PROJECT] - This project is "OpenFOAM" - do not change export WM_PROJECT=OpenFOAM # [projectDir] - directory containing this OpenFOAM version. # \- When this file is located as $WM_PROJECT_DIR/etc/bashrc, the next lines # should work when sourced by BASH or ZSH shells. If this however fails, # set one of the fallback values to an appropriate path. # # This can be removed if an absolute path is provided for WM_PROJECT_DIR # later on in this file # -- projectDir="${BASH_SOURCE:-${ZSH_NAME:+$0}}"; [ -n "$projectDir" ] && projectDir="$(\cd $(dirname $projectDir)/.. && \pwd -L)" ||\ # projectDir="$HOME/OpenFOAM/OpenFOAM-$WM_PROJECT_VERSION" projectDir="/opt/openFoam/OpenFOAM-$WM_PROJECT_VERSION" # projectDir="/usr/local/OpenFOAM/OpenFOAM-$WM_PROJECT_VERSION" ################################################################################ Code:
root@localhost:/opt/OpenFoam/OpenFOAM-v1912# foamSystemCheck Checking basic system... ----------------------------------------------------------------------- Shell: ERROR: Cannot identify the current shell. OpenFOAM v1912 is compatible with csh, tcsh, ksh and bash. Host: localhost OS: Linux version 4.9.186-17655189 User: root System check: FAIL ================== Your system is not currently compatible with OpenFOAM installation requirements. Review the error messages and consult the documentation for further instructions. root@localhost:/opt/OpenFoam/OpenFOAM-v1912# Code:
root@localhost:/opt/OpenFoam/OpenFOAM-v1912# ./Allwmake -j -s -l Logging wmake -all output to 'log.linuxARM64ArmDPInt64Opt' Compiling enabled on 8 cores gcc=/bin/gcc clang= mpirun=/bin/mpirun make=/bin/make cmake=/bin/cmake wmake=/opt/OpenFoam/OpenFOAM-v1912/wmake/wmake m4=/bin/m4 flex=/bin/flex compiler=unknown ======================================== 2020-05-01 02:44:49 -0400 Starting compile OpenFOAM-v1912 Allwmake Arm system compiler linuxARM64ArmDPInt64Opt, with SYSTEMOPENMPI openmpi-system ======================================== lemon: lemon.c armclang -mcpu=native -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -ffp-contract=fast -ffast-math -O3 -armpl -fPIC lemon.c -o /opt/OpenFoam/OpenFOAM-v1912/wmake/platforms/linuxARM64Arm/lemon make: armclang: Command not found make: *** [Makefile:88: /opt/OpenFoam/OpenFOAM-v1912/wmake/platforms/linuxARM64Arm/lemon] Error 127 Done logging to 'log.linuxARM64ArmDPInt64Opt' root@localhost:/opt/OpenFoam/OpenFOAM-v1912# Thanks! Bonus: I assume these same configuration should be used for OpenFoam V7 and foam-extend? |
May 1, 2020, 03:56 |
Herpes Free Engineer
Rep Power: 12 |
Could you please report the error in one of the issue trackers? The links below may help.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 1, 2020, 18:28 |
Reported the error to gitlab linked in your sig
Sultan Islam
Rep Power: 10 |
May 2, 2020, 05:43 |
Rep Power: 12 |
some answer thereat: https://develop.openfoam.com/Develop...am/issues/1695
May 4, 2020, 15:17 |
#5 | |
Mark Olesen
Rep Power: 40 |
Please note that the information given on the ARM site is for using the armclang compiler. This is a clang-based compiler with ARM-specific optimizations, but is not the same as running a regular clang on an ARM system. If the command "armclang" is accessible on your system, you can use it, otherwise stick to gcc or clang which you quite likely do have on your system. I cannot say if the armclang performance is significantly different to what regular gcc or clang provide. |
May 5, 2020, 16:46 |
I see
#6 | |
Sultan Islam
Rep Power: 10 |
I untar into /opt/OpenFOAM. Edited bashrc to point to that directory. Sourced etc/bashrc And then ran. /Allwmake -j It was running until this error: Code:
In file included from /opt/OpenFoam/OpenFOAM-v1912/src/OpenFOAM/lnInclude/VectorSpace.H:270, from /opt/OpenFoam/OpenFOAM-v1912/src/OpenFOAM/lnInclude/Field.H:50, from /opt/OpenFoam/OpenFOAM-v1912/src/OpenFOAM/lnInclude/scalarField.H:41, from /opt/OpenFoam/OpenFOAM-v1912/src/OpenFOAM/lnInclude/dimensionSet.H:48, from /opt/OpenFoam/OpenFOAM-v1912/src/OpenFOAM/lnInclude/dimensionedType.H:43, from lnInclude/ddtScheme.H:45, from finiteVolume/ddtSchemes/boundedDdtScheme/boundedDdtScheme.H:50, from finiteVolume/ddtSchemes/boundedDdtScheme/boundedDdtSchemes.C:28: /opt/OpenFoam/OpenFOAM-v1912/src/OpenFOAM/lnInclude/VectorSpaceI.H:346:13: note: because ‘Foam::SymmTensor<double>’ has user-provided ‘void Foam::VectorSpace<Form, Cmpt, Ncmpts>::operator=(const Foam::VectorSpace<Form, Cmpt, Ncmpts>&) [with Form = Foam::SymmTensor<double>; Cmpt = double; unsigned char Ncmpts = 6]’ 346 | inline void Foam::VectorSpace<Form, Cmpt, Ncmpts>::operator= | ^~~~ g++: fatal error: Killed signal terminated program cc1plus compilation terminated. make: *** [/opt/OpenFoam/OpenFOAM-v1912/wmake/rules/General/transform:35: /opt/OpenFoam/OpenFOAM-v1912/build/linuxARM64GccDPInt32Opt/src/finiteVolume/finiteVolume/ddtSchemes/CrankNicolsonDdtScheme/CrankNicolsonDdtSchemes.o] Error 1 make: *** Waiting for unfinished jobs.... root@localhost:/opt/OpenFoam/OpenFOAM-v1912# I did notice this during build in the beginning: Code:
======================================== KAHIP decomposition ./makeKAHIP: 64: local: -DWM_DP: bad variable name --------------------------------------------------- Optional component (KAHIP) had build issues OpenFOAM will nonetheless remain largely functional --------------------------------------------------- ======================================== METIS decomposition Missing sources: 'metis-5.1.0' Possible download locations for METIS : http://glaros.dtc.umn.edu/gkhome/metis/metis/overview http://glaros.dtc.umn.edu/gkhome/fetch/sw/metis/metis-5.1.0.tar.gz --------------------------------------------------- Optional component (METIS) had build issues OpenFOAM will nonetheless remain largely functional --------------------------------------------------- ======================================== CGAL/boost CGAL include: /opt/OpenFoam/ThirdParty-v1912/platforms/linuxARM64Gcc/CGAL-4.9.1/include CGAL library: /opt/OpenFoam/ThirdParty-v1912/platforms/linuxARM64Gcc/CGAL-4.9.1/lib64 boost include: /opt/OpenFoam/ThirdParty-v1912/platforms/linuxARM64Gcc/boost_1_64_0/include boost library: /opt/OpenFoam/ThirdParty-v1912/platforms/linuxARM64Gcc/boost_1_64_0/lib64 ======================================== FFTW fftw include: /opt/OpenFoam/ThirdParty-v1912/platforms/linuxARM64Gcc/fftw-3.3.7/include fftw library: /opt/OpenFoam/ThirdParty-v1912/platforms/linuxARM64Gcc/fftw-3.3.7/lib64 ======================================== ADIOS2 ./makeAdios2: 64: local: -DWM_DP: bad variable name --------------------------------------------------- Optional component (ADIOS2) had build issues OpenFOAM will nonetheless remain largely functional --------------------------------------------------- ======================================== Done ThirdParty Allwmake ======================================== |
May 6, 2020, 19:41 |
Fixed the Issue!
Sultan Islam
Rep Power: 10 |
Great news, I was able to compile and install OpenFOAM-v1912 arm64 directly inside my Ubuntu 19.10 install inside a Proot Container running on an Android Phone.
So what I did differently this time was: -First made sure give termux (my terminal to launch the container) wakelock such that android doesn't kill the session -Downloading the latest tar file named OpenFOAM-v1912200314.tar.gz (kept the original Thirdparty-v1912.tar.gz as it was unchanged) -Untar into my new directory located in /opt/OpenFOAM - [Optional: I hear its not needed as this is automated] I did go into the etc/bashrc and un-commented the build directory pointing to openfoam in opt and commented the build directory pointing to openfoam in $Home - sourced etc/bashrc in terminal (my terminal was already in the OpenFOAM-v1912 directory) - Did foamSystemCheck command and noticed that for me that openfoam cannot figure out which shell I am using (I am using bash), and this is due to permissions with proot containers (it shouldn't be an issue) - ran ./Allwmake -j4 -l (I chose 4 because anything higher would cause resource issues with my soc) - It build correctly and I was able to run foamInstallationTest and even commands such as blockMesh/simpleFoam/etc. -Finally i edited in my bashrc in my home directory with this line: Code:
alias of1912='source /opt/OpenFOAM/OpenFOAM-v1912/etc/bashrc'; I created a run directory and then copied over a few tutorials to test. elbow, pitzDaily, airFOIL2D, simpleCar, rotarDisk all ran using both manual commands and there Allrun scripts. ParaFoam worked out of the box with my Paraview 5.8.0 (installed from Ubuntu Repo using apt-get) I was able to visualize this all on a phone: https://imgur.com/Ph62I0z The only issue I have is that motorBike didn't run correctly with Allrun, it ran to quickly and when I tried to open results, paraview didn't have the data for p,U,nu,etc. I even ran it manually using blockMesh > snappyHexMesh (it took around 800 seconds to run) > SimpleFoam, and it still couldnt find the proper results in paraview. I chalk this down to openmpi support for my device. However largely everything else works |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
[ANSYS Meshing] Creating a 2D Mesh with Ansys Workbench for OpenFOAM v1912 | fanta | ANSYS Meshing & Geometry | 1 | April 4, 2020 08:59 |
[OpenFOAM] selecting cmake-Version when building Paraview from OpenFOAM | molli123 | ParaView | 0 | September 13, 2018 08:33 |
[OpenFOAM.org] Building OpenFOAM 3.0 on ArchLinux | coldice | OpenFOAM Installation | 8 | January 31, 2016 11:39 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
